1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: epicsqt first try
To: Andrew Rhyder <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Thu, 24 Mar 2011 18:21:02 -0700
On 09:31 Tue 22 Mar     , Andrew Rhyder wrote:
> There is not much wrong with your code below, but I believe you always need to create widgets like QLabels (our EPICS flavor or otherwise) within a main window widget.
No need of main window
or layout
or "how to use Qt" book. ;-)
> Also, the CA connection is not established automatically, you have to call the 'activate()' method once the widget is created.
Ok, that was the missing part
#include <QApplication>
#include <QCaLabel.h>
int main(int argc, char *argv[])
  QApplication a(argc, argv);
  QCaLabel label("DMC2183:1:DscrptnSI");
  label.activate();
  label.show();
  return a.exec();
> Calling 'activate()' is a minor overhead that I would like to avoid for simple widgets that could otherwise just 'go' but allows for widgets that take multiple PVs and then require macro substitution to be applied to those PVs.
I love the ASgui utility
The documentation is quite good to get you started (once you find and read it ;)
I would love to see more advanced widgets.
Overall this ca_framework is...
... awesome!
Emmanuel
RE: epicsqt first try Andrew Rhyder
epicsqt first try emmanuel_mayssat
Prev: PyEpics 3.1.0 Matt Newville
Next: GPIB DCL Robert Emery
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: epicsqt first try Andrew Rhyder
Next: RE: epicsqt first try Andrew Rhyder
