Emmanuel,
You can do this with an asub routine, or with SNL code, or, if
the transformation is simple enough, with an aCalcout record
(http://www.aps.anl.gov/bcda/synApps/calc/R2-8/aCalcoutRecord.html)
from the synApps calc module.
Tim
----- Original Message -----
> From: "emmanuel mayssat" <[email protected]>
> To: "EPICS tech-talk" <[email protected]>
> Sent: Monday, March 21, 2011 6:42:00 PM
> Subject: waveform transformation
> Hello,
> I have a waveform.
> I would like to apply a linear transformation to that waveform.
> The simplest case would be
> * calibration of ADC raw values to voltages
> * transformation from voltage to engineering units
> Is there a simple way to do this?
> Ultimately I would like to use a subArray....
> So far the only way I have found to do the above is to this is by
> transforming the waveform in the C code.
> Is it possible to do the same in the IOC database?
> Emmanuel
Tim Mooney ([email protected]) (630)252-5417
Software Services Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
- waveform transformation emmanuel_mayssat
Re: non-normalized X WaveF / Y WaveF display Eric Norum
epicsqt emmanuel_mayssat
<2011>
2025
2026
non-normalized X WaveF / Y WaveF display emmanuel_mayssat
<2011>
2025
2026
