1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: non-normalized X WaveF / Y WaveF display
To: [email protected]
Cc: EPICS tech-talk <[email protected]>
Date: Mon, 21 Mar 2011 19:18:51 -0700
On the MEDM X/Y plot resource palette -- in the "Count Num or Channel" field.
On Mar 21, 2011, at 5:34 PM, [email protected] wrote:
> On 17:24 Mon 21 Mar     , Eric Norum wrote:
>>> I assume I have to generate the X waveform = # samples on frequency range.
>>> But can medm autoscale on the horizontal axis since range and # of samples can be changed at every scan by operator?
>>> (I believe so, but ...)
>> Yes, but remember that the waveform record does not post monitors on its .NORD field.   Thus it's a good idea to have a dummy longin record that is forward linked from the waveform record and which gets its value from the waveform record .NORD field and then have MEDM monitor the number of samples to display from that longin record.
> Ok, ... but where in the medm display do I specify this longin record?
> Emmanuel
Eric Norum
[email protected]
non-normalized X WaveF / Y WaveF display emmanuel_mayssat
Re: non-normalized X WaveF / Y WaveF display Eric Norum
Re: non-normalized X WaveF / Y WaveF display emmanuel_mayssat
Prev: Re: non-normalized X WaveF / Y WaveF display emmanuel_mayssat
Next: Re: waveform transformation Tim Mooney
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: epicsqt emmanuel_mayssat
