Title: Re: epicsqt
I am just testing the epicsqt-1.1.2 package after seeing your post.
This works for me:
// Generate the caLabelWidgetTest.ui with Qt-designer and the epicsqt plugin.
// QCaLablel is drawn in designer as a Widget.
// uic caLabelWidgetTest.ui > ui_caLabelWidgetTest.h
#include "ui_caLabelWidgetTest.h"
#include <QtGui/QApplication>
#include <QCaLabel.h>
int main(int argc, char *argv[])
QApplication a(argc, argv);
QWidget w;
Ui::Form ui;
ui.setupUi(&w);
//QCaLabel label("DMC2183:1:DscrptnSI");
//ui.qcalabelplugin->setText(QApplication::translate("MainWindow","DMC2183:1:DscrptnSI", 0, QApplication::UnicodeUTF8));
ui.qcalabelplugin->setText(QApplication::translate("MainWindow","demo:voltage", 0, QApplication::UnicodeUTF8));
w.show();
return a.exec();
The demo:voltage PV is from the sequencer demo.
Ivan
I am testing your epicsqt package.
I may be interested in wrapping it in SIP so that your libraries can
be used in python (which I use heavily)
But before I do so, I am trying to test your Qt designer plugin.
First, I would like to use a simple QCaLabel object.
> #include <QApplication>
> label.show();
> return a.exec();
I have
$ caget DMC2183:1:DscrptnSI
DMC2183:1:DscrptnSI OC:C50-C70-C90
I compile without any errors.... I start the program... and I don't see anything.
I assume that QCaLabel can be used to display the content of a string PV. What am I doing wrong?
Emmanuel
Re: pdevLibVirtualOS Michael Davidsaver
epicsQt Szalata, Zenon M.
<2011>
2025
2026
epicsqt emmanuel_mayssat
<2011>
2025
2026
