1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: epicsQt
To: Andrew Rhyder <[email protected]>
Date: Wed, 23 Mar 2011 15:28:38 -0700
Hi Andrew,
Today I downloaded qpicsQt 1.1.2, built it, and did some testing.
I still get the error:
"Bug in QCaStringFormatting::formatString(). The QVariant type was not expected"
when I try to display contents of a waveform record in a QCaLabel.  Here is my waveform record:
record( waveform, "$(P):WF:ERROR"){
  field( DESC, "Error Message:")
  field( NELM, "128")
  field( FTVL, "CHAR")
The same is also true if I connect a QCaShape object to a bit field in a mbbiDirect record.
On a more positive note, I have just finished developing a “byte monitor” widget, which is similar to its counterpart in EDM.
So, now I have two custom CA aware widgets, which work for me.  The other is a “specialized” toggle button.
Zen
Prev: Re: epicsqt So, Sung-Leung
Next: New "model 3" motor driver for Parker ACR controllers Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: epicsQt Szalata, Zenon M.
