1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: asynPortDriver Question
Date: Sat, 26 Mar 2011 20:41:42 -0700
Thanks Mark,
I actually implemented this with an overlaid rectangle with a visibility rule.  Generally I avoid piling number of widgets on top of each other, so I was looking for a solution to avoid that.
Zen
> -----Original Message-----
> From: Mark Rivers [mailto:[email protected]]
> Sent: Saturday, March 26, 2011 4:11 PM
> To: Szalata, Zenon M.
> Cc: [email protected]
> Hi Zen,
> I don't think you can do that.  The first order problem is that there is no
> connection from the asyn driver to the AO:SC record, since it uses soft device
> support, not asyn device support.  I don't think there is a way to propogate
> alarm status between records at the database level except by using the MS
> qualifier on input and output links.  But I'm not a database programming
> expert, perhaps there is a way to do this.
> But if you want to indicate a problem to the user in the edm screen you can
> have another widget whose visibility or color is controlled by the AO record's
> alarm status.
> Mark
> ________________________________
> From: Szalata, Zenon M. [mailto:[email protected]]
> Sent: Sat 3/26/2011 2:54 PM
> To: Mark Rivers
> Subject: asynPortDriver Question
> Hi Mark,
> I am using a four record set to write analog data to a set point register in a
> power supply and to keep reading and writing this register in sync.  This
> technique is what you suggested as a solution to a question I had.  Here are
> the four records:
> #---- $(DESC) ------------------------------
> record( ao, "$(P):AO:SC:$(ITEM)"){
>   field( DESC, "$(DESC):")
>   field( OUT,  "$(P):AO:$(ITEM) PP")
>   field( DRVL, "$(DRVL)")
>   field( DRVH, "$(DRVH)")
> record( ao, "$(P):AO:$(ITEM)"){
>   field( SDIS, "$(P):AO:$(ITEM):Sync.PACT")
>   field( DISV, "1")
>   field( DTYP, "asynFloat64")
>   field( OUT,  "@asyn($(PORT),0,1)AO_$(ITEM)")
> record( ai, "$(P):AI:$(ITEM)"){
>   field( INP,  "@asyn($(PORT),0,1)AI_$(ITEM)")
>   field( SCAN, "I/O Intr")
>   field( EGU,  "$(EGU)")
>   field( FLNK, "$(P):AO:$(ITEM):Sync")
> record( ao, "$(P):AO:$(ITEM):Sync"){
>   field( DOL,  "$(P):AI:$(ITEM) NPP")
>   field( OMSL, "closed_loop")
>   field( OUT,  "$(P):AO:SC:$(ITEM) PP")
> An EDM Text Control widget connected to the "AO:SC" record is used to write a
> new value to the set point register.  Depending on some other configuration
> parameters that the power supply is set up with, write set point might fail.
> When that happens, my writeFloat64 routine returns asynError and the SEVR
> gets set INVALID in the "$(P):AO:$(ITEM)" record.  I would like the EDM widget
> to reflect this alarm condition.  It does not do it because it is not connected to
> the AO record that is in an alarm state and I don't know how to transfer this
> alarm information to the record the EDM widget is connected to.
> I wonder if it is possible to control alarm state of an EPICS record via
> asynPortDriver, a record that is not being processed at the moment?  That is,
> is there a way other than returning a failed completion code from a
> processing routine (like writeInt32) to put a record in an alarm state?
> Thanks,
> Zen
asynPortDriver Question Szalata, Zenon M.
RE: asynPortDriver Question Mark Rivers
Prev: Re: GPIB DCL Eric Norum
Next: Re: asynPortDriver Question Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: asynPortDriver Question Mark Rivers
