1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: asynPortDriver Question
To: EPICS Tech Talk <[email protected]>
Date: Mon, 28 Mar 2011 10:29:22 +0200
On 27.03.2011 00:11 Mark Rivers wrote:
Hi Zen,
I don't think you can do that.  The first order problem is that there is no connection from the asyn driver to the AO:SC record, since it uses soft device support, not asyn device support.  I don't think there is a way to propogate alarm status between records at the database level except by using the MS qualifier on input and output links.  But I'm not a database programming expert, perhaps there is a way to do this.
You can point any unused input link of your "target" record to a field in your "source" record and make it "MS" to pull the severity from the "source". I know people that are regularly abusing the SIML input link to achieve this....
HTH,
Ralph
RE: asynPortDriver Question Szalata, Zenon M.
RE: asynPortDriver Question Mark Rivers
Prev: RE: asynPortDriver Question Szalata, Zenon M.
Next: how to build c++ yangyong203
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: asynPortDriver Question Szalata, Zenon M.
