1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: CA and threads
To: Dirk Zimoch <[email protected]>
Cc: [email protected]
Date: Tue, 29 Mar 2011 10:32:54 -0500
Hi Dirk,
On Tuesday 29 March 2011 09:45:08 Dirk Zimoch wrote:
> Unfortunately this behavior bites me now. After upgrading to a new OS
> and thus Tcl/Tk version, it turned out that monitors in our EPICS-Tcl
> interface did not work any more. This is because Tcl now can be compiled
> "thread aware" (which has been done by the distributor) and refuses to
> accept commands that come from a different thread.
Do you maintain your own Tcl interface to CA?  I know that we still use Tcl/Tk
quite a lot here at APS — maybe if you were to post a question about CA and
Tcl rather than the CA internals you might get a more useful and positive
answer.  I suspect that this problem might have already been solved, or there
will at least be other people interested in helping to solve it (collaboration
is almost always better than forking).
There are probably other ways to fix this too, you may be able to register the
callback thread with Tcl to allow yourself to run the command in that same
thread.  However I'm pretty sure that CA runs callbacks from a separate thread
for each CA server, so you can't just register one thread, you have to be
prepared to do it lots of times.  You may need to register and use an
epicsThreadPrivate variable to store any thread-specific data, and use
epicsAtThreadExit() to clean up when CA is closing down.
HTH,
- Andrew
An error is only a mistake if you don't learn from it.
When you learn something from it, it becomes a lesson.
CA and threads Dirk Zimoch
Re: CA and threads Andrew Johnson
Re: CA and threads Dirk Zimoch
Prev: Re: CA and threads Robert Soliday
Next: Any upcoming EPICS training Jimmy Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: 64-bit Channel Archiver Robert Petkus
