1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: base 3.14.12 problem on solaris-spac
To: EPICS <[email protected]>
Date: Thu, 31 Mar 2011 15:01:45 +0200
Hi all,
While building base 3.14.12 on solaris-sparc I get the following error message at several places:
gmake -C O.solaris-sparc -f ../Makefile TOP=../../.. T_A=solaris-sparc install Can't locate EPICS/Path.pm in @INC (@INC contains: /afs/psi.ch/group/8431/dirk/solaris/epics-3.14.12/bin/solaris-sparc/../../lib/perl /afs/psi.ch/group/8431/dirk/solaris/epics-3.14.12/bin/solaris-sparc /usr/local/lib/perl5/5.8.8/sun4-solaris /usr/local/lib/perl5/5.8.8 /usr/local/lib/perl5/site_perl/5.8.8/sun4-solaris /usr/local/lib/perl5/site_perl/5.8.8 /usr/local/lib/perl5/site_perl .) at /afs/psi.ch/group/8431/dirk/solaris/epics-3.14.12/bin/solaris-sparc/fullPathName.pl line 22. BEGIN failed--compilation aborted at /afs/psi.ch/group/8431/dirk/solaris/epics-3.14.12/bin/solaris-sparc/fullPathName.pl line 22.
The problem is that at an early stage when installing header files and $(INSTALL_LOCATION)/lib does not yet exist, perl is looking for already installed scripts.
To solve that problem, the perl scripts have to be installed early.
Dirk
More base 3.14.12 problem on solaris-spac Dirk Zimoch
Prev: CAEN SY 8800 peter.owens
Next: More base 3.14.12 problem on solaris-spac Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
