1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: More base 3.14.12 problem on solaris-spac
To: EPICS <[email protected]>
Date: Thu, 31 Mar 2011 15:24:24 +0200
After installing $(INSTALL_LOCATION)/lib/perl/EPICS/*.pm manually, the next problem comes here:
mkdir /afs/psi.ch/group/8431/dirk/solaris/epics-3.14.12/html
mkdir /afs/psi.ch/group/8431/dirk/solaris/epics-3.14.12/html/freeList
Installing html /afs/psi.ch/group/8431/dirk/solaris/epics-3.14.12/html//gpHash/gpHash.html
mkdir /afs/psi.ch/group/8431/dirk/solaris/epics-3.14.12/html/gpHash
gmake[3]: Leaving directory `/afs/psi.ch/group/8431/dirk/cvs/base-3.14.12/src/libCom/O.solaris-sparc' gmake[2]: Leaving directory `/afs/psi.ch/group/8431/dirk/cvs/base-3.14.12/src/libCom'
gmake -C ./toolsComm install
gmake[2]: Entering directory `/afs/psi.ch/group/8431/dirk/cvs/base-3.14.12/src/toolsComm'
gmake -C ./antelope install
gmake[3]: Entering directory `/afs/psi.ch/group/8431/dirk/cvs/base-3.14.12/src/toolsComm/antelope' gmake -C O.solaris-sparc -f ../Makefile TOP=../../../.. T_A=solaris-sparc install gmake[4]: Entering directory `/afs/psi.ch/group/8431/dirk/cvs/base-3.14.12/src/toolsComm/antelope/O.solaris-sparc' /afs/psi.ch/sys/@sys/sepp/bin/cc -c -D_POSIX_C_SOURCE=199506L -D_XOPEN_SOURCE=500 -DUNIX -DSOLARIS=8 -mt -D__EXTENSIONS__ -xO4 -I. -I../O.Common -I. -I.. -I/afs/psi.ch/group/8431/dirk/solaris/epics-3.14.12/include/os/solaris -I/afs/psi.ch/group/8431/dirk/solaris/epics-3.14.12/include ../main.c gmake[4]: *** No rule to make target `/afs/psi.ch/group/8431/dirk/solaris/epics-3.14.12/lib/solaris-sparc/libCom.a', needed by `antelope'. Stop.
There seems to be something seriously wrong with the dependencies.
Any idea? I had no problems on Linux or windows. Also no problem to install 3.14.8 on solaris.
Dirk
Dirk Zimoch wrote:
Hi all,
While building base 3.14.12 on solaris-sparc I get the following error message at several places:
gmake -C O.solaris-sparc -f ../Makefile TOP=../../.. T_A=solaris-sparc install Can't locate EPICS/Path.pm in @INC (@INC contains: /afs/psi.ch/group/8431/dirk/solaris/epics-3.14.12/bin/solaris-sparc/../../lib/perl /afs/psi.ch/group/8431/dirk/solaris/epics-3.14.12/bin/solaris-sparc /usr/local/lib/perl5/5.8.8/sun4-solaris /usr/local/lib/perl5/5.8.8 /usr/local/lib/perl5/site_perl/5.8.8/sun4-solaris /usr/local/lib/perl5/site_perl/5.8.8 /usr/local/lib/perl5/site_perl .) at /afs/psi.ch/group/8431/dirk/solaris/epics-3.14.12/bin/solaris-sparc/fullPathName.pl line 22. BEGIN failed--compilation aborted at /afs/psi.ch/group/8431/dirk/solaris/epics-3.14.12/bin/solaris-sparc/fullPathName.pl line 22.
The problem is that at an early stage when installing header files and $(INSTALL_LOCATION)/lib does not yet exist, perl is looking for already installed scripts.
To solve that problem, the perl scripts have to be installed early.
Dirk
Re: More base 3.14.12 problem on solaris-spac Ralph Lange
Re: More base 3.14.12 problem on solaris-spac Dirk Zimoch
Prev: base 3.14.12 problem on solaris-spac Dirk Zimoch
Next: Re: More base 3.14.12 problem on solaris-spac Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
