1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: More base 3.14.12 problem on solaris-spac
To: "Dirk Zimoch" <[email protected]>, "EPICS" <[email protected]>
Date: Thu, 31 Mar 2011 10:11:42 -0500
And the EPICS documentation has clearly stated in the top-level README
file since EPICS 3.14.10 that make 3.81 is required:
http://www.aps.anl.gov/epics/base/R3-14/10-docs/README.html
"GNU make
You must use GNU make, gnumake, for any EPICS builds. Set your path so
that a gnumake version 3.81 or later is available."
-----Original Message-----
[mailto:[email protected]] On Behalf Of Dirk Zimoch
Sent: Thursday, March 31, 2011 10:01 AM
To: EPICS
Subject: Re: More base 3.14.12 problem on solaris-spac
Hi all,
Several people pointed me to the right direction: make version.
After building version 3.81 for my solaris box everything works. I had
3.79.1 before (which is by the way the version that comes with Tornado
2.2).
Now everything works.
Thanks to all who helped so quickly.
Dirk
PS: Was it really (I mean REALLY) necessary to make the build rules
incompatible to older make versions?
More base 3.14.12 problem on solaris-spac Dirk Zimoch
Re: More base 3.14.12 problem on solaris-spac Dirk Zimoch
Prev: RE: More base 3.14.12 problem on solaris-spac Mark Rivers
Next: EPICS Collaboration Meeting Fall 2011, First Announcement Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: More base 3.14.12 problems on solaris-spac (version 5.8) Dirk Zimoch
