1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EDM start window position
To: John Dobbins <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Thu, 31 Mar 2011 11:26:29 -0700
1/ alternative would be X11 geometry parameter + wmctrl for workspace switch
Great for intial setup of workspaces
2/ You could use a windows matching utility.
On linux gnome, that would be devilspie package
http://burtonini.com/blog/computers/devilspie/
Great for cleaning up already opened workspaces or enforcing location of GUIs.
Can you use different user accounts for the different display configuration?
That you would simplify your configuration/script quite a lot
E
On 11:05 Thu 31 Mar     , John Dobbins wrote:
> All,
> I am wondering if there is a way to specify the location of an EDM
> window from the command line.
> I would like to have a script open multiple EDM windows at specified
> positions. I can set the default position for each window in the file
> itself but the desired positions are different for someone with a quad
> display than for someone with a single monitor.
> Advice?
> Regards,
> John Dobbins
> Cornell Laboratory for Accelerator-based Sciences and Education
> Cornell University
Emmanuel
EDM start window position John Dobbins
Prev: EPICS Collaboration Meeting Fall 2011, First Announcement Dirk Zimoch
Next: devIocStats 3.1.5 released Allison, Stephanie
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: EDM start window position John Dobbins
Next: EDM start window position Scott Baily
