Yes, there is a way to specify the location of an EDM window from the
commandline. For example -open screen.edl?300?400 will open screen.edl
at X=300, Y=400 (You can also specify a display if your monitors are
configured as separate displays). See:
http://ics-web.sns.ornl.gov/edm/edmUserManual/index.html#id3488573
However, I modified our copy of EDM to handle multiple displays in the
same way as our previous display manager. Since our 6 monitor displays
are configured as a single display, we run a separate copy of edm (with
a different port) for each monitor. An environmental variable (set to
the upper left hand corner for each screen) gets added to the window
positions. Essentially, this make window positions relative to the
upper left hand corner of the monitor. I can make the code available if
anyone is interested.
Scott Baily
AOT-IC, MS H820
Los Alamos National Laboratory
Los Alamos, NM 87545
ph: (505) 606-2260
RE: MAXv question matthew.pearson
Re: sequencer on 64bit linux Andrew Johnson
<2011>
2025
2026
Re: EDM start window position emmanuel_mayssat
EPICS Collaboration Meeting Fall 2011, First Announcement Dirk Zimoch
<2011>
2025
2026
