1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: sequencer on 64bit linux
To: Benjamin Franksen <[email protected]>
Cc: [email protected]
Date: Tue, 5 Apr 2011 11:06:56 +0200
[Andrew, I meant to send my reply to the list, sorry. This is an edited and
extended version, BTW.]
Am Montag, 4. April 2011, um 17:24:14 schrieben Sie:
> On Sunday 03 April 2011 11:34:39 Benjamin Franksen wrote:
> > since CA does not support 64bit integer types, I wonder what to do about
> > SNL programs with declarations like
> > long x;
> > assign x to "whatever";
> > on a system where sizeof(long)==8 (like linux-x86_64). Note that in SNL
> > code, the type of a variable determines the request type for CA
requests.
> > In this case DBR_LONG is certainly wrong, as it is defined to be 32bit.
> Here's a naive question for FAQ purposes: Why can't you do what the
> database does and make the SNL 'long' type map to an epicsInt32 on all
> architectures? I personally understand the major disadvantage to doing
> that when interfacing to external APIs, but I think it's worth explaining
> exactly why you can't do that as part of this discussion.
Why not map an SNL 'long' to a C 'epicsInt32'?
Well, I *could* of course do it like that, but I think it's not a good idea.
As Andrew already hinted at, the main problem is that in SNL code you want
to smoothly interoperate not only with EPICS records via CA but also with C
library functions. For instance, many functions from the standard C library
return long, e.g. strtol(). I think it would be quite surprising to have SNL
code like
long n = strtol(str,0,0);
result in a "warning: conversion from long to int may change its value" or
something similar. Or, even worse, to get no such warning and instead,
depending on the input string, get a completely wrong result due to
overflow. I fear that this is an invitation for subtle, very hard to find
bugs.
BTW, Ralph Lange suggested that to make it easier to write portable SNL
code, I should allow use of the standard C fixed-size integer types in SNL.
This would mean you can say
uint32_t x;
assign x to "...";
and be sure that this is an unsigned 32 bit integer, regardless of
architecture and OS. I think this is a good idea and I plan to add this to
my development version, so it will be in 2.1, but not in 2.0.13.
> I think making this an error is probably the right solution; the message
> should explain that the variable needs to be an int to assign it on any
> 64-bit systems, and the documentation should explain that the SNL code
> will need to marshal data values between two variables if the program
> really does need to use a 64-bit long variable.
Ok, I will try to give a nice error message in this case (currently it just
outputs the generic "a variable of this type cannot be assigned to a PV").
> > BTW, I doubt that the current stable version 2.0.12 works properly on
> > such systems but I haven't tried it yet.
> On little-endian (e.g. Intel/AMD) architecture systems the LSB is always
at
> the pointed-to byte, thus long variables appear to work fine on most
> current 64-bit systems as long as the values are all within the positive
> 32-bit range. This will fail as soon as either side tries to use a
> negative value, but many sites may already be using this version without
> realizing the problem because of that.  It would be good to see a 2.0.13
> release with this fixed though, and the issue documented.
I think I can do that.
The main problem I see is that 2.0.12 says
typedef long pvLong;
and then happily assigns pvLong from and to dbr_long_t. As you say, this is
not catastrophic in most cases, but I need to check if there are things like
sizeof(pvLong) used in places where in fact sizeof(dbr_long_t) would be
correct.
Cheers
Ben
Mitglied der Hermann von Helmholtz-Gemeinschaft Deutscher Forschungszentren e.V
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn- Rudolph
Geschäftsführer: Prof. Dr. Anke Rita Kaysser-Pyzalla, Prof. Dr. Dr. h.c. Wolfgang Eberhardt, Dr. Ulrich Breuer
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
Re: sequencer on 64bit linux J. Lewis Muir
Re: sequencer on 64bit linux Andrew Johnson
sequencer on 64bit linux Benjamin Franksen
Prev: Re: sequencer on 64bit linux Benjamin Franksen
Next: Re: MAXv question Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: sequencer on 64bit linux J. Lewis Muir
