Hi Matthew,
All 16 IO pins are available on the front panel.
Available on the back are only pins 0-5 and 8-15. Pin 6 is available if
you sacrifice AUX-S. Which is not possible for us because we use AUX for
the motor power.
We are using a special version of the MAXv with support for absolute SSI
encoders. They need clock signals and we use IO 0-3 for that. Thus I
would really like to use pins 8-15 for the power monitoring. Maybe it is
possible to configure which set to use.
Dirk
[email protected] wrote:
Hi Dirk,
I think Austen Rose has implemented this in his new Asyn version of the MAXv driver, and that relies on the front panel connector.
Are all 16 pins available on the front panel? If not, Austen suggested we use both sets (0-7 on the front panel, and 8-15 on the backplane).
It's also possible that we're using the existing DPM support in the OMS58 driver.
Cheers,
Matthew
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Ron Sluiter
Sent: 01 April 2011 16:36
To: Dirk Zimoch
Cc: EPICS
Subject: Re: MAXv question
On 4/1/2011 7:36 AM, Dirk Zimoch wrote:
So before breaking anything: Does anyone see a problem with that?
Driver Power Monitoring (DPM) was never implemented for the
MAXv so there is no problem with breaking existing applications.
I don't recall why I did not implement DPM for the MAXv, but
I second Mark's comments and add that features like DPM
add clutter to device drivers and would be better implemented
at a higher level (which is possible with the new asyn motor device
driver support).
Hope this helps,
Ron
- MAXv question Dirk Zimoch
- Re: MAXv question Ron Sluiter
- RE: MAXv question matthew.pearson
Re: sequencer on 64bit linux Benjamin Franksen
Re: sequencer on 64bit linux J. Lewis Muir
<2011>
2025
2026
Agilent/HP E440B driver Pierrick Hanlet
<2011>
2025
2026
