1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: how to use EPICS driver of MicroResearch PMC-EVR
To: <[email protected]>, <[email protected]>, <[email protected]>
Date: Tue, 5 Apr 2011 23:16:34 +0800
I want to use my PMC-EVR, the EPICS driver is from
the underlying files related to the PMC-EVR mainly are mrfPmc.c and os/vxWorks/mrfPmcOSD.c, but I don't know which dbd file, record support and device support I should use. The er and erevent record, as well as the device/driver support devMrfEr.c/drvMrfEr.c may not fit, since some registers of PMC-EVR are different from EVR-200/EVR-230's, such as FPS(front panel signal) map.
So what should I do for building EPICS application for PMC-EVR? How did you build it for your PMC-EVR?
Lin Wang
Re: how to use EPICS driver of MicroResearch PMC-EVR Michael Davidsaver
Prev: Re: sequencer on 64bit linux J. Lewis Muir
Next: Re: sequencer on 64bit linux Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: sequencer on 64bit linux Andrew Johnson
Next: Re: how to use EPICS driver of MicroResearch PMC-EVR Michael Davidsaver
