1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: sequencer on 64bit linux
To: [email protected]
Date: Tue, 5 Apr 2011 10:27:19 -0500
Hi Lewis,
On Tuesday 05 April 2011 09:45:30 J. Lewis Muir wrote:
> Say I have a longout record on an IOC and want to write to its
> VAL field from an SNL program running in a different IOC.  What
> type should I use for the SNL variable in order to be portable?
>  int32_t?  Or is there actually no way to be portable because
> the size of the longout record's DBF_LONG VAL field can vary
> depending on the architecture for which the longout record was
> built and because CA doesn't support 64-bit integer types?
Since R3.14.10 the DBF_LONG field type has mapped to epicsInt32, a 32-bit
integer typedef for int (or int32_t where __STDC_VERSION__ >= 199901L) that is
defined in epicsTypes.h.  I don't know of any architectures where those are
not synonymous nowadays, but some might come along in the future.  IOCs built
with releases prior to 3.14.10 didn't work properly on 64-bit architectures
anyway.  The Channel Access dbr_long_t from db_access.h is also a typedef for
epicsInt32.
> It would seem to me that the only way to actually make anything
> portable is to use fixed size types across the board.  That is,
> in the example above, make the type of the longout record's VAL
> field a 64-bit signed integer (e.g. DBF_INT64), make CA support
> 64-bit signed integers, and let me use int64_t as the type of
> the variable in the SNL program used to write to the VAL field.
64-bit integers were not fully supported on some of our older OSs and are not
efficient on CPUs that have only 32-bit registers, but replacing 64-bit with
32-bit in the above paragraph that's what we currently have; use int variables
in the sequencer to get a 32-bit integer on all the architectures I know of.
- Andrew
An error is only a mistake if you don't learn from it.
When you learn something from it, it becomes a lesson.
sequencer on 64bit linux Benjamin Franksen
Re: sequencer on 64bit linux Benjamin Franksen
Re: sequencer on 64bit linux J. Lewis Muir
Prev: how to use EPICS driver of MicroResearch PMC-EVR 王林
Next: Re: sequencer on 64bit linux Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: sequencer on 64bit linux J. Lewis Muir
