Hi Dirk,
On Friday 01 April 2011 05:06:35 Dirk Zimoch wrote:
> "../epicsExceptionTest.cpp", line 111: Error: Cannot create a variable
> for abstract class exThread.
> Anyway, the solution is to define a destructor for exThread:
Applied, thanks.
> "../../../../src/cas/generic/st/casStreamOS.cc", line 325: Error:
> "casStreamOS::armSend()" has already been called and cannot be defined
> inline.
I deleted the inline attribute to armSend()
> cc: Warning: illegal option -fno-strict-aliasing
> "/usr/local/lib/perl5/5.8.8/sun4-solaris/CORE/proto.h", line 31: syntax
> error before or at: __attribute__
> warning: syntax error: empty declaration
> "/usr/local/lib/perl5/5.8.8/sun4-solaris/CORE/proto.h", line 41: syntax
> [... 1700 more lines of error messages ]
> Obviously the C code has been generated for the gnu compiler, not for
> the native compiler. Checking the result of "perl perlConfig.pl cc"
> shows the discrepancy. A modification in the Makefile skips this build
> if the current compiler and the compiler used for perl do not match:
> ifeq ($(findstring $(OS_CLASS),WIN32 cygwin32),)
> # Doesn't build on WIN32
> ifndef Cap5_COMPILER
> Cap5_COMPILER := $(shell $(PERL) perlConfig.pl ccname)
> export Cap5_COMPILER
> endif
> ifeq ($(notdir $(firstword $(CC))),$(Cap5_COMPILER))
Unfortunately this change disables building on some other architectures that
worked before; you'll have to apply this manually or otherwise disable
building cap5 here for future releases.
The two changes above have been committed to the 3.14 branch and will be
included in any future 3.14.13 release.
- Andrew
An error is only a mistake if you don't learn from it.
When you learn something from it, it becomes a lesson.
- base 3.14.12 problem on solaris-spac Dirk Zimoch
- Re: More base 3.14.12 problem on solaris-spac Dirk Zimoch
- Re: More base 3.14.12 problems on solaris-spac (version 5.8) Dirk Zimoch
Re: how to use EPICS driver of MicroResearch PMC-EVR Michael Davidsaver
Ether/IP array limits Stephen Lewis
<2011>
2025
2026
EDM start window position John Dobbins
<2011>
2025
2026
