1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: mbbo soft raw support
To: <[email protected]>
Date: Sat, 9 Apr 2011 00:36:39 +0200
Hello,
the devMbboSoftRaw outputs the RVAL field (which has type DBF_ULONG) with
request type DBR_LONG. This means that if you point the OUT link to a calc
record's A field, an RVAL of e.g. 0xffff0000 (all 16 bits set, left shifted by
16) will result in a negative value. OTOH, if you use the INPA input link to
get the value, then A will contain a positive number, because the request type
in this case is DBR_DOUBLE. This behaviour is somewhat surprising to the
uninitiated. Off-hand, I do not know of a good way to fix this, but maybe
someone else has an idea?
(Life would be *so* much simpler if CA had been designed with support for
unsigned integer types. And, just BTW, as it stands CA for EPICS V4 (a.k.a.
pvAccess+pvData) will have exactly the same sort of problems. That is, unless
we promise that servers never use unsigned integer types for publicly
accessible record or struct fields.)
Cheers
Ben
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführer: Prof. Dr. Anke Rita Kaysser-Pyzalla, Prof. Dr. Dr. h.c. Wolfgang Eberhardt, Dr. Ulrich Breuer
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
Prev: AW: Re: alarm auto dialer Moeller, Markus
Next: Re: motor record RBV wmoore
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: vxworks BSP sysBusToLocalAdrs not support PCI space 王林
