1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: motor record RBV
To: "Ron Sluiter" <[email protected]>
Cc: [email protected]
Date: Mon, 11 Apr 2011 11:39:05 -0400 (EDT)
Using the SET mode is a very good point.  But I believe in this case
Mark's suggestion of using autosave is the right way for me to go long
term. Thanks for all the support.
Wesley
> Hello Wesley,
> I am not sure this answers your question, but...
> The motor record has a SET field which can have values; 0:"Use" or
> 1:"Set".
> When the SET field is in the "Use" mode and user enters a new position,
> the motor moves to that position.
> If the SET field is in the "Set" mode and the user enters a new position
> the motor record redefines the
> current target positions (VAL/DVAL/RVAL) and the feedback positions
> (RBV/DRBV/RRBV) to the new
> value; i.e., it "sets" both the target and feedback positions to the new
> value.
> Hope this helps,
> Ron
> On 4/8/2011 11:25 AM, [email protected] wrote:
>> The motors that are an issue have no encoders or limit switches, so
>> nothing for me to reference.  Does anyone have a slick solution for
>> "restoring" a motor's RBV?  Perhaps, something like setting the offset
>> to
>> the last RBV after a reboot or crash.
>> Thanks for your time.
>> Wesley
motor record RBV wmoore
Re: motor record RBV Ron Sluiter
Prev: mbbo soft raw support Benjamin Franksen
Next: vxworks BSP sysBusToLocalAdrs not support PCI space 王林
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: motor record RBV Ron Sluiter
Next: AW: Re: alarm auto dialer Moeller, Markus
