1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Python EPICS interface (pyepics 3.1.1) double waveform record (NLEM = 65535 ) record handling exception
To: "Matt Newville" <[email protected]>, "Ritesh Sugandhi" <[email protected]>
Cc: [email protected]
Date: Tue, 12 Apr 2011 10:55:38 -0500
It's actually EPICS_CA_MAX_ARRAY_BYTES, not EPICS_CA_MAX_ARRAY_SIZE.  That must be set on both the IOC machine and the Python client machine.
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Matt Newville
Sent: Tuesday, April 12, 2011 10:52 AM
To: Ritesh Sugandhi
Subject: Re: Python EPICS interface (pyepics 3.1.1) double waveform record (NLEM = 65535 ) record handling exception
Hi Ritesh,
What is EPICS_CA_MAX_ARRAY_SIZE set to?  If left unset, I believe you
would see exactly this behavior (arrays using up to 16384 bytes would
work, while larger arrays would fail.
I haven't tested with python 3.2 on 64-bit linux (yet?), so it's
possible there are issues, but I'd expect that if short arrays of
doubles work that longer ones would too.
--Matt Newville
On Tue, Apr 12, 2011 at 10:29 AM, Ritesh Sugandhi
<[email protected]> wrote:
> Dear sir,
> My Enviorment is
> pyepics-3.1.1,
> python 3.2
> Linux kernal  2.6.18-194 ; 64 bit
> Context: Testing pyepics library
> Problem:
> I am using supplied database (test/pydebug.db) and I am not able to use the
> double wave form record of 64k elements. while double wave form record of 2k
> elements works fine.
> Any suggestion are welcome.
> Best regards
> ---- EPICS shell------------------
> epics> dbpr Py:double64k 2
> ACKS: NO_ALARM      ACKT: YES           APST: Always        ASG:
> BKPT: 00            BUSY: 0             DESC: long double waveform
> DISA: 0             DISP: 0             DISS: NO_ALARM      DISV: 1
> DTYP: Soft Channel  EGU:                EVNT: 0             FLNK:CONSTANT 0
> FTVL: DOUBLE        HOPR: 0             INP:CONSTANT        LCNT: 0
> LOPR: 0             MPST: Always        NAME: Py:double64k  NELM: 65536
> NORD: 0             NSEV: NO_ALARM      NSTA: NO_ALARM      PACT: 0
> PHAS: 0             PINI: NO            PREC: 0             PRIO: LOW
> PUTF: 0             RARM: 0             RPRO: 0             SCAN: Passive
> SDIS:CONSTANT       SEVR: INVALID       SIML:CONSTANT       SIMM: NO
> SIMS: NO_ALARM      SIOL:CONSTANT       STAT: UDF           TIME:
> <undefined>
> TPRO: 0             TSE: 0              TSEL:CONSTANT       UDF: 1
> VAL: (nil)
> ------------- Python shell -----------------------------
>>>> pv1=PV('Py:double64k')
> Traceback (most recent call last):
>   File "_ctypes/callbacks.c", line 259, in 'calling callback function'
>   File
> "/home/ITER/sugandr/Desktop/epics-python/Python-3.2/lib/python3.2/site-packages/epics/ca.py",
> line 391, in _onGetEvent
>>>>     value = dbr.cast_args(args).contents
> ValueError: NULL pointer access
Re: Python EPICS interface (pyepics 3.1.1) double waveform record (NLEM = 65535 ) record handling exception Andrew Johnson
Python EPICS interface (pyepics 3.1.1) double waveform record ( NLEM = 65535 ) record handling exception Ritesh Sugandhi
Re: Python EPICS interface (pyepics 3.1.1) double waveform record ( NLEM = 65535 ) record handling exception Matt Newville
Prev: Re: Python EPICS interface (pyepics 3.1.1) double waveform record ( NLEM = 65535 ) record handling exception Matt Newville
Next: Re: Python EPICS interface (pyepics 3.1.1) double waveform record (NLEM = 65535 ) record handling exception Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
