1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: 24-bit digitizer ICS-710 EPICS driver is available
To: "Hu, Yong" <[email protected]>, "EPICS tech-talk" <[email protected]>
Date: Tue, 12 Apr 2011 18:02:41 -0400
Hello All,
I'm sorry that I didn't realize the NSLS-II Mercurial Repository is not
accessible from outside BNL until Andrew pointed out today.
But I'm going to put the documentation and source codes on SourceForge
(http://epics.hg.sourceforge.net/hgweb/epics/) soon.
Yong
>-----Original Message-----
>From: [email protected] [mailto:tech-talk-
>[email protected]] On Behalf Of Hu, Yong
>Sent: Tuesday, April 12, 2011 4:04 PM
>To: EPICS tech-talk
>Subject: 24-bit digitizer ICS-710 EPICS driver is available
>Hello All,
>The EPICS/Linux driver for compactPCI digitizer ICS-710 is now
>available. Here're some features of this cPCI digitizer:
>1) 24-bit;
>2) Programmable sampling rate: 1KS/s ~ 216KS/s;
>3) Programmable analog bandwidth: 10KHz ~ 150KHz;
>4) input voltage range: -10V ~ +10V;
>5) on-board memory: 1M samples (4M Bytes);
>6) 8-channel to 32 per card;
>7) Support external triggering;
>The EPICS driver source code is available from NSLS-2 Controls
Mercurial
>repository:
>http://code.nsls2.bnl.gov/hg/ics710/
>Get a copy: hg clone http://code.nsls2.bnl.gov/hg/ics710
>If you need the static-built executable for easy setup, please contact
>me.
>Regards,
>Yong Hu
>NSLS-II Controls Group
24-bit digitizer ICS-710 EPICS driver is available Hu, Yong
Prev: 24-bit digitizer ICS-710 EPICS driver is available Hu, Yong
Next: Re: Python EPICS interface (pyepics 3.1.1) double waveform record (NLEM = 65535 ) record handling exception Ritesh Sugandhi
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: ioc segfault if - c seq flag is not set or +c? Abadie Lana
