1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: 24-bit digitizer ICS-710 EPICS driver is available
To: "EPICS tech-talk" <[email protected]>
Date: Tue, 12 Apr 2011 16:04:28 -0400
Hello All,
The EPICS/Linux driver for compactPCI digitizer ICS-710 is now
available. Here're some features of this cPCI digitizer:
1) 24-bit;
2) Programmable sampling rate: 1KS/s ~ 216KS/s;
3) Programmable analog bandwidth: 10KHz ~ 150KHz;
4) input voltage range: -10V ~ +10V;
5) on-board memory: 1M samples (4M Bytes);
6) 8-channel to 32 per card;
7) Support external triggering;
The EPICS driver source code is available from NSLS-2 Controls Mercurial
repository:
http://code.nsls2.bnl.gov/hg/ics710/
Get a copy: hg clone http://code.nsls2.bnl.gov/hg/ics710
If you need the static-built executable for easy setup, please contact
me.
Yong Hu
NSLS-II Controls Group
RE: 24-bit digitizer ICS-710 EPICS driver is available Hu, Yong
Prev: RE: How to execute CSS/BOY directly in OPIruntime mode ? Chen, Xihui
Next: RE: 24-bit digitizer ICS-710 EPICS driver is available Hu, Yong
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Python EPICS interface (pyepics 3.1.1) double waveform record (NLEM = 65535 ) record handling exception Jeff Hill
