1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Python EPICS interface (pyepics 3.1.1) double waveform record (NLEM = 65535 ) record handling exception
To: "'Andrew Johnson'" <[email protected]>, <[email protected]>
Date: Mon, 18 Apr 2011 16:28:55 -0600
> > or how
> > EPICS would deal with arrays approaching 2Gb.
> I think the only issue would be that there has to be enough RAM in the
> IOC for the multiple copies of the data that are made between the device,
> record and CA server.
Currently another issue, on 64 bit hosts, will be no arrays larger than
roughly 4294967279 Bytes - which is actually pretty close to 2GB.
Perhaps I shouldn?t be surprised that it didn?t take that long to get from
16kB to 4GB!
Jeff
______________________________________________________
Jeffrey O. Hill           Email        [email protected]
LANL MS H820              Voice        505 665 1831
Los Alamos NM 87545 USA   FAX          505 665 5107
Message content: TSPA
With sufficient thrust, pigs fly just fine. However, this is
not necessarily a good idea. It is hard to be sure where they
are going to land, and it could be dangerous sitting under them
as they fly overhead. -- RFC 1925
> -----Original Message-----
> From: [email protected] [mailto:tech-talk-
> [email protected]] On Behalf Of Andrew Johnson
> Sent: Wednesday, April 13, 2011 9:11 AM
> To: [email protected]
> Subject: Re: Python EPICS interface (pyepics 3.1.1) double waveform
> On Wednesday 13 April 2011 09:23:43 Matt Newville wrote:
> > > I am also interested to know how far we can go with the array size in
> > > EPICS and PyEPICS interface.
> > There is no explicit limit on array size that doesn't exist in EPICS.
> > With Area Detector, it's not unusual for us to be transferring 8Mb
> > arrays.   I don't know what the largest verified array size is, or how
> IOC for
> the multiple copies of the data that are made between the device, record
> and
> CA server.  The record obviously has to have the storage for its copy,
> and the
> CA server reserves EPICS_CA_MAX_ARRAY_BYTES + a little bit for buffering
> on
> the way out.  Whatever device support you're using might want its own
> copy as
> well, but that might be avoidable depending on the actual code in use.
> - Andrew
> An error is only a mistake if you don't learn from it.
> When you learn something from it, it becomes a lesson.
Python EPICS interface (pyepics 3.1.1) double waveform record ( NLEM = 65535 ) record handling exception Ritesh Sugandhi
Re: Python EPICS interface (pyepics 3.1.1) double waveform record (NLEM = 65535 ) record handling exception Ritesh Sugandhi
Re: Python EPICS interface (pyepics 3.1.1) double waveform record (NLEM = 65535 ) record handling exception Matt Newville
Re: Python EPICS interface (pyepics 3.1.1) double waveform record (NLEM = 65535 ) record handling exception Andrew Johnson
Prev: RE: ca.py - Throws error - workaround Jeff Hill
Next: RE: Does EPICS Base support multi-thread on vxWorks 6.3? Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Python EPICS interface (pyepics 3.1.1) double waveform record (NLEM = 65535 ) record handling exception Andrew Johnson
Next: 24-bit digitizer ICS-710 EPICS driver is available Hu, Yong
