1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: ioc segfault if - c seq flag is not set or +c?
To: "Allison, Stephanie" <[email protected]>
Date: Thu, 14 Apr 2011 10:34:34 -0500
On 4/14/11 10:01 AM, Allison, Stephanie wrote:
> I discovered that even building RTEMS 32 bit sequences (using
> the RTEMS 32bit tool chain) on a linux-x86_64 build is
> problematic as the 64bit-built SNC compiler will, in some
> special cases, convert the .st file to a buggy .c file (in the
> initialization of the state event masks).
I had a similar problem compiling on RHEL 5 (linux-x86_64) for
VxWorks (vxWorks-ppc603, vxWorks-ppc604, and
vxWorks-ppc604_long) using EPICS 3.14.11 (+ Known Problems
patches), SEQ 2.0.12 (as packaged in SynApps 5.5), and the
Tornado 2.0.2 toolchain.  I haven't had time to investigate, but
indeed the SNC compiler was generating .c files that the
cross-compiler could not compile.  I think the SNC compiler was
generating integer values greater than what could fit in 32 bits
which the cross-compiler choked on.
Lewis
J. Lewis Muir
Software Engineer
IMCA-CAT
Re: ioc segfault if - c seq flag is not set or +c? Benjamin Franksen
ioc segfault if - c seq flag is not set or +c? Abadie Lana
RE: ioc segfault if - c seq flag is not set or +c? Abadie Lana
RE: ioc segfault if - c seq flag is not set or +c? Allison, Stephanie
Prev: RE: ioc segfault if - c seq flag is not set or +c? Allison, Stephanie
Next: Re: ca.py - Throws error - workaround Matt Newville
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: ioc segfault if - c seq flag is not set or +c? Benjamin Franksen
