Hi Luca,
I hope it's OK with you that I'm sending the message to Tech-Talk,
where there are many people with much better understanding of Channel
Access than I have.
On Thu, Apr 14, 2011 at 1:58 AM, Luca Luisa <[email protected]> wrote:
> Hi,
> I'm working with PyEpics version 3.1.1.
> My QT Python application communicates with many EPICS servers where hundred
> of PVs are delivered.
> Our application has to deal with any EPICS server
> disconnection/re-connection that can happen during the application run.
> Each PV used by this QT Python application has a callback function added
> with the module "add_callback()".
> When I noticed an EPICS server disconnection, I clear the callbacks with the
> method "clear_callbacks()".
> When any EPICS server re-connect again, I try to add again another callback
> function to the same PV instance previously created, if fails (the
> add_callback returns None) I re-create the PV instance again and try to add
> the callback function.
> But in the cycle above described used to handle the dynamic connection to
> EPICS server, I get a lot of unknown errors in the terminal from where I
> launch my application, those are:
> TypeError: __on_connect() got an unexpected keyword argument 'count'
> Traceback (most recent call last):
> File "_ctypes/callbacks.c", line 295, in 'calling callback function'
> File "/usr/local/lib/python2.6/dist-packages/epics/ca.py", line 420, in
> _onGetEvent
> args.usr(value=value, **kwds)
> Our application is very complex so I cannot send you an example.
> In order to remove this error that full-fills the terminal window, I had to
> change the "ca.py" source with a try: except: statement.
> The diff is:
> 419,423c419,420
> < try:
> < if hasattr(args.usr, '__call__'):
> < args.usr(value=value, **kwds)
> < except:
> My solution is a pure workaround to make my application working and I got
> success but I would like to know if this is a known error or my way to
> handle connection/disconnection of a EPICS server is wrong.
> Many thanks
> Ing. Luca Luisa
I'm reluctant to make that change, as it's the only place ca.py can
tell the programmer that there was an error in running the
user-supplied callback and this change silences that message.
This message:
> _onGetEvent
says that PV.__on_connect() -- the internally defined connection
callback for a PV -- is being run as a change-in-value callback. I'm
not sure how that's even possible.
I'm not sure this is necessary. Have you tried not doing this?
Obviously, you won't get a callback from a disconnected PV, and will
get a callback upon reconnection, but I would think that's not worse
than explicitly clearing and re-setting callbacks. I can verify that
it does works for me in simple test scripts to not clear "change
value" callbacks and restart the server IOC.
For PV.add_callback() to return None, the PV has to be unconnected --
or at least that's the intention. So it's hard to understand what's
happening if you wait for reconnection to add a callback. I do think
it shouldn't be necessary to re-create the PV.
I'm not sure whether this is related to using QT. A minimal example
would be really helpful.
--Matt
- Re: ca.py - Throws error - workaround Tim Mooney
- RE: ca.py - Throws error - workaround Jeff Hill
Re: ioc segfault if - c seq flag is not set or +c? J. Lewis Muir
<2011>
2025
2026
RE: ioc segfault if - c seq flag is not set or +c? Abadie Lana
<2011>
2025
2026
