1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Does EPICS Base support multi-thread on vxWorks 6.3?
To: [email protected]
Cc: [email protected]
Date: Fri, 15 Apr 2011 10:07:26 -0500
Hi Lorna,
On Friday 15 April 2011 02:34:53 [email protected] wrote:
> We developed a client based on libca (EPICS Base 3.14.9), which will
> create it's own worker thread on construction. But we found it working
> strangely on vxWorks (ppc-603). Whenever a second EPICS client is created
> (meaning there are now 2 EPICS worker threads on vxWorks), the CPU usage
> became 100%.
> From the profile, we found the ca_pend_event is consuming lots of the CPU.
> Meanwhile, it seems epicsMutex is failing to do the lock for the second
> EPICS client??
EPICS should work fine on your hardware and OS combination, this is probably
an application programming issue.
Are these two threads sharing a single CA client context?  Hopefully Jeff Hill
will respond here too, but you might want to read this and the following
sections of the CA Reference Manual for some ideas:
  http://www.aps.anl.gov/epics/base/R3-14/12-docs/CAref.html#Thread
In particular if you're experienced in writing multi-threaded code you might
want to use ca_enable_preemptive_callback mode and completely avoid having to
call ca_pend_event() in your code.
- Andrew
An error is only a mistake if you don't learn from it.
When you learn something from it, it becomes a lesson.
Re: Does EPICS Base support multi-thread on vxWorks 6.3? lorna . zhang
Prev: Support for Highland V344/V346 waveform generators? Ralph Lange
Next: EPICS Device Support for the Sis3302 Ernest L. Williams Jr.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Does EPICS Base support multi-thread on vxWorks 6.3? lorna . zhang
Next: Re: Does EPICS Base support multi-thread on vxWorks 6.3? lorna . zhang
