1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: gateway aborted by SIGBUS
To: <[email protected]>
Date: Wed, 20 Apr 2011 15:15:28 +0000
Recently we have had three read/write gateways (version 2.0.4.0) crash at different times with the following error appearing in the gateway log.
PV Gateway Aborted (SIGBUS)
The crashes have all occurred when doing a caput thorough the gateway.
The server option on the gateway causes an immediate restart of the gateway however the restart doesn't seem to cure the problem with the particular PV's we are writing to although read access to all PV's is fine. Manually stopping and restarting the gateway get this back to a working state so presumably the time taken to do the restart manually is significant.
So a couple of questions:
1) Has anyone else seen this?
2) What's the best way to debug this? Presumably as its SIGBUS it has something to do with stack size or byte alignment or similar. So presumably I need to get a core dump. Is there any additional debugging in the gateway I can enable which may help?
Pete Leicester
Diamond Light Source
Re: gateway aborted by SIGBUS Martin L. Smith
Prev: Re: ca.py - Throws error - workaround Matt Newville
Next: Re: ca.py - Throws error - workaround Geoff Savage
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Handling of Array in CaChannel library Wang Xiaoqiang
Next: Re: gateway aborted by SIGBUS Martin L. Smith
