1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: ca.py - Throws error - workaround
To: [email protected]
Date: Wed, 20 Apr 2011 09:24:05 -0500
Hi Luca,
Is it possible to send a short example of code and the full error
message you're seeing?  That would really help diagnose the problem.
It should not be necessary (or even useful) to re-create a PV on
reconnection.
--Matt
On Wed, Apr 20, 2011 at 2:21 AM, Luca Luisa <[email protected]> wrote:
> Hi,
> I tried to types of code:
> 1. in the first one I don't disconnect the PV when the Server disconnects
> and I just wait an automatic reconnection.
> 2. in the second I disconnect the PV, and re-create it again when the server
> connects again.
> In both cases I get the same error.
> Luca
> On 04/19/2011 12:19 AM, Jeff Hill wrote:
>> Hi Matt, Luca,
>> Sorry about the delay responding - I was away on business at the end of
>> last
>> week.
>>>> EPICS server, I get a lot of unknown errors in the terminal
>>>> from where I launch my application, those are:
>>>> TypeError: __on_connect() got an unexpected keyword argument 'count'
>>>> Traceback (most recent call last):
>>>>  File "_ctypes/callbacks.c", line 295, in 'calling callback function'
>>>>  File "/usr/local/lib/python2.6/dist-packages/epics/ca.py",
>>>> line 420, in _onGetEvent
>>>>    args.usr(value=value, **kwds)
>> Despite some similarities, I don’t believe that this particular message
>> originates from the ca client library.
>> Note also that if you do not unsubscribe when the circuit becomes
>> unresponsive then the ca client library will auto-magically re-subscribe
>> on
>> your behalf should the channel need to be reconnected on a fresh TCP
>> circuit.
>> Jeff
>> ______________________________________________________
>> Jeffrey O. Hill           Email        [email protected]
>> LANL MS H820              Voice        505 665 1831
>> Los Alamos NM 87545 USA   FAX          505 665 5107
>> Message content: TSPA
>> With sufficient thrust, pigs fly just fine. However, this is
>> not necessarily a good idea. It is hard to be sure where they
>> are going to land, and it could be dangerous sitting under them
>> as they fly overhead. -- RFC 1925
>>> -----Original Message-----
>>> From: [email protected] [mailto:tech-talk-
>>> [email protected]] On Behalf Of Matt Newville
>>> Sent: Thursday, April 14, 2011 10:07 AM
>>> To: [email protected]; EPICS Tech Talk
>>> Hi Luca,
>>> I hope it's OK with you that I'm sending the message to Tech-Talk,
>>> where there are many people with much better understanding of Channel
>>> Access than I have.
>>> On Thu, Apr 14, 2011 at 1:58 AM, Luca Luisa<[email protected]>  wrote:
>>>> Hi,
>>>> I'm working with PyEpics version 3.1.1.
>>>> My QT Python application communicates with many EPICS servers where
>>> hundred
>>>> of PVs are delivered.
>>>> Our application has to deal with any EPICS server
>>>> disconnection/re-connection that can happen during the application run.
>>>> Each PV used by this QT Python application has a callback function
>>> added
>>>> with the module "add_callback()".
>>>> When I noticed an EPICS server disconnection, I clear the callbacks
>>> with the
>>>> method "clear_callbacks()".
>>>> When any EPICS server re-connect again, I try to add again another
>>> callback
>>>> function to the same PV instance previously created, if fails (the
>>>> add_callback returns None) I re-create the PV instance again and try to
>>> add
>>>> the callback function.
>>>> But in the cycle above described used to handle the dynamic connection
>>> to
>>>> EPICS server, I get a lot of unknown errors in the terminal from where
>>> I
>>>>  File "/usr/local/lib/python2.6/dist-packages/epics/ca.py", line 420,
>>> in
>>>> _onGetEvent
>>>> Our application is very complex so I cannot send you an example.
>>>> In order to remove this error that full-fills the terminal window, I
>>> had to
>>>> change the "ca.py" source with a try: except: statement.
>>>> The diff is:
>>>> 419,423c419,420
>>>> <      try:
>>>> <       if hasattr(args.usr, '__call__'):
>>>> <               args.usr(value=value, **kwds)
>>>> <      except:
>>>> My solution is a pure workaround to make my application working and I
>>> got
>>>> success but I would like to know if this is a known error or my way to
>>>> handle connection/disconnection of a EPICS server is wrong.
>>>> Many thanks
>>>> Ing. Luca Luisa
>>> I'm reluctant to make that change, as it's the only place ca.py can
>>> tell the programmer that there was an error in running the
>>> user-supplied callback and this change silences that message.
>>> This message:
>>> in
>>>> _onGetEvent
>>> says that PV.__on_connect() -- the internally defined connection
>>> callback for a PV -- is being run as a change-in-value callback.  I'm
>>> not sure how that's even possible.
>>> with the
>>> I'm not sure this is necessary.  Have you tried not doing this?
>>> Obviously, you won't get a callback from a disconnected PV, and will
>>> get a callback upon reconnection, but I would think that's not worse
>>> than explicitly clearing and re-setting callbacks.  I can verify that
>>> it does works for me in simple test scripts to not clear "change
>>> value" callbacks and restart the server IOC.
>>> callback
>>> add
>>> For PV.add_callback() to return None, the PV has to be unconnected --
>>> or at least that's the intention. So it's hard to understand what's
>>> happening if you wait for reconnection to add a callback.  I do think
>>> it shouldn't be necessary to re-create the PV.
>>> I'm not sure whether this is related to using QT.  A minimal example
>>> would be really helpful.
>>> --Matt
Re: ca.py - Throws error - workaround Matt Newville
RE: ca.py - Throws error - workaround Jeff Hill
Re: ca.py - Throws error - workaround Luca Luisa
Prev: RE: Handling of Array in CaChannel library Wang Xiaoqiang
Next: gateway aborted by SIGBUS peter.leicester
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: ca.py - Throws error - workaround Luca Luisa
Next: Re: ca.py - Throws error - workaround Geoff Savage
