1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: shell command arguments limitation?
To: "Hu, Yong" <[email protected]>
Cc: [email protected]
Date: Wed, 20 Apr 2011 10:02:31 -0700
The ioc shell doesn't call its registered functions with individual arguments so the limit you're describing does not exist.  iocsh handler functions are called with a single argument -- a pointer to an array of argument unions.  The only limit that I can see is the amount of memory available to hold this array.
On Apr 20, 2011, at 9:53 AM, Hu, Yong wrote:
> I guess the limitation is determined by the C++/C language. As I recalled from some textbooks, 256 Max. arguments in one function call in C++ and 128 in C.
> But I guess nobody writes a function with tens of arguments. I did write a configuration function as ioc shell with 9 arguments which works well.
> Yong
>> -----Original Message-----
>> From: [email protected] [mailto:tech-talk-
>> [email protected]] On Behalf Of Jim Chen
>> Sent: Wednesday, April 20, 2011 12:36 PM
>> To: [email protected]
>> Subject: shell command arguments limitation?
>> Hello,
>> I remember there used to be a limitation for the number of arguments in
>> a single ioc shell command (configuration for example). What exact
>> number is it since R3.14.11 release or is there a one please?
>> Thanks,
>> Jim
>> Hytec Electronics Ltd.
>> Tel: +44 (0) 118 975 7770
>> Fax: +44 (0) 118 975 7566
>> Web: www.hytec-electronics.co.uk
>> Incorporated in England No 1246940
>> VAT NO GB 285 2479 27
Eric Norum
[email protected]
Re: shell command arguments limitation? Andrew Johnson
New sequencer bugfix release candidate Benjamin Franksen
seq-2-0-13-rc2 Benjamin Franksen
shell command arguments limitation? Jim Chen
RE: shell command arguments limitation? Hu, Yong
Prev: RE: shell command arguments limitation? Hu, Yong
Next: Re: shell command arguments limitation? Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
