On Wednesday 20 April 2011 12:02:31 Eric Norum wrote:
> The ioc shell doesn't call its registered functions with individual
> arguments so the limit you're describing does not exist. iocsh handler
> functions are called with a single argument -- a pointer to an array of
> argument unions. The only limit that I can see is the amount of memory
> available to hold this array.
There may be a limit to the length of the command line buffer which would
restrict the number of arguments, but that probably depends on the underlying
OS and what the EPICS_READLINE setting is.
Jim may have been remembering the arguments to the vxWorks taskSpawn()
function, which is limited to 10 arguments. I'm not aware of a limit in the
vxWorks shell either, but there may be one that I haven't come across yet.
- Andrew
An error is only a mistake if you don't learn from it.
When you learn something from it, it becomes a lesson.
- RE: shell command arguments limitation? Jim Chen
- New sequencer bugfix release candidate Benjamin Franksen
- RE: shell command arguments limitation? Hu, Yong
- Re: shell command arguments limitation? Eric Norum
Re: status of Debian/Ubuntu packages/repositories Andrew Johnson
<2011>
2025
2026
<2011>
2025
2026
