1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Handling of String Array in CaChannel library
To: "Ritesh Sugandhi" <[email protected]>
Cc: [email protected]
Date: Thu, 21 Apr 2011 22:23:18 +0200
It seems for DBF_STRING array there is certain overhead, 16 bytes, when reading from CA client. In your case, setting EPICS_CA_MAX_ARRAY_BYTES to 2621416 works. I verified with caget from epics base
[-bash SLSBASE=/work]$ export EPICS_CA_MAX_ARRAY_BYTES=2621415
[-bash SLSBASE=/work]$ /usr/local/epics/base/bin/SL5-x86/caget -d DBR_STRING swave
Read operation timed out: some PV data was not read.
swave
    *** CA error The requested data transfer is greater than available memory or EPICS_CA_MAX_ARRAY_BYTES
[-bash SLSBASE=/work]$ export EPICS_CA_MAX_ARRAY_BYTES=2621416
[-bash SLSBASE=/work]$ /usr/local/epics/base/bin/SL5-x86/caget -#10 -d DBR_STRING swave
swave
    Data type:      DBR_STRING (native: DBF_STRING)
    Element count:  10
    Value:
The reason behind should be answered by experts then.
Best,
Xiaoqiang
-----Original Message-----
Sent: Thu 4/21/2011 5:25 PM
To: Wang Xiaoqiang
Subject: Handling of String Array in CaChannel library
Dear Sir,
thanks for sharing the code,  using your code I have mange to read and write
array a simple array.
I am able to successfully enhance the code to  read and write a double array
of size 64k ( 65535) elements. in this case I am using
EPICS_CA_MAX_ARRAY_BYTES configuration was 524280 ( i.e. 65535 * 8 bytes for
double). this works successfully
I have declared a string Array of 65535 elements and this time I have setted
EPICS_CA_MAX_ARRAY_BYTES to 2621400 (i.e. 40*65535 considering size of 40
bytes for string) at server and client side. running with this gives error
$ python2.6 ca-channel-v1.6-demo-waveform-string-64k.py
('total values are', 65535)
but when I set EPICS_CA_MAX_ARRAY_BYTES to greater then 26214*20 at client
side.* I get the correct data at client side.
code is
from CaChannel import *
from random    import *
def main():
  try:
    channel = CaChannel('Py:string64k')
    channel.searchw()
    newval=[]
    for i in range(65535):
newval.append("ABCDEFGHIJKLMNOPQRSTUVWXYZ0123456789-$#")
    channel.putw(newval)
    print('total values are',channel.element_count())
    print(channel.getw())
    del channel
  except CaChannelException, status:
    print ca.message(status)
main()
record is
 record(waveform, "Py:string64k")
    field(DESC, "string array")
    field(NELM, "65535")
    field(FTVL, "STRING")
On Wed, Apr 20, 2011 at 4:21 PM, Wang Xiaoqiang <[email protected]>wrote:
> Hi,
> Load this into your IOC:
> record(waveform, "cawave")
>     field(DESC, "numeric array")
>     field(NELM, "20")
>     field(FTVL, "DOUBLE")
> >>> import CaChannel
> >>> pv=CaChannel.CaChannel('cawave')
> >>> pv.searchw()
> >>> pv.getw()
> [0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0,
> 0.0, 0.0, 0.0, 0.0, 0.0]
> >>> pv.putw(range(12))
> >>> pv.getw()
> [0.0, 1.0, 2.0, 3.0, 4.0, 5.0, 6.0, 7.0, 8.0, 9.0, 10.0, 11.0, 0.0, 0.0,
> 0.0, 0.0, 0.0, 0.0, 0.0, 0.0]
> Xiaoqiang
> *From:* [email protected] [mailto:
> [email protected]] *On Behalf Of *Ritesh Sugandhi
> *Sent:* Wednesday, April 20, 2011 3:48 PM
> *To:* [email protected]
> *Subject:* Handling of Array in CaChannel library
> Dear Sir,
> Could I get an example of how to handle sub array and waveforms records in
> CaChannel-v1.6 library code.
> Best regards,
> ritesh Sugandhi
RE: Handling of String Array in CaChannel library Jeff Hill
Handling of String Array in CaChannel library Ritesh Sugandhi
Prev: Re: PyEpics and Python threads Matt Newville
Next: Re: PyEpics and Python threads Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Handling of String Array in CaChannel library Ritesh Sugandhi
Next: RE: Handling of String Array in CaChannel library Jeff Hill
