1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Handling of String Array in CaChannel library
To: "'Wang Xiaoqiang'" <[email protected]>, "'Ritesh Sugandhi'" <[email protected]>
Cc: [email protected]
Date: Thu, 21 Apr 2011 17:13:07 -0600
> It seems for DBF_STRING array there is certain
> overhead, 16 bytes, when reading from CA client.
> In your case, setting EPICS_CA_MAX_ARRAY_BYTES to
> 2621416 works (but 2621415 didn?t work).
As I recall, the size of the ca protocol header (16 bytes) _is_ implicitly
added to the users request in EPICS_CA_MAX_ARRAY_BYTES so that such
anomalies don?t occur, but perhaps I have neglected to add implicitly
additional amounts for the larger (by 8 bytes) protocol header emitted when
the request size is more than 0xffff bytes. Admittedly, this doesn?t yet
fully explain the 15/16 transition of the issue that you are observing.
In any case I have created a bug entry so that this issue can be tracked,
and fixed.
https://bugs.launchpad.net/epics-base/+bug/768670
Jeff
______________________________________________________
Jeffrey O. Hill           Email        [email protected]
LANL MS H820              Voice        505 665 1831
Los Alamos NM 87545 USA   FAX          505 665 5107
Message content: TSPA
With sufficient thrust, pigs fly just fine. However, this is
not necessarily a good idea. It is hard to be sure where they
are going to land, and it could be dangerous sitting under them
as they fly overhead. -- RFC 1925
> -----Original Message-----
> From: [email protected] [mailto:[email protected]]
> On Behalf Of Wang Xiaoqiang
> Sent: Thursday, April 21, 2011 2:23 PM
> To: Ritesh Sugandhi
> Hi,
> It seems for DBF_STRING array there is certain overhead, 16 bytes, when
> reading from CA client. In your case, setting EPICS_CA_MAX_ARRAY_BYTES to
> 2621416 works. I verified with caget from epics base
> [-bash SLSBASE=/work]$ export EPICS_CA_MAX_ARRAY_BYTES=2621415
> [-bash SLSBASE=/work]$ /usr/local/epics/base/bin/SL5-x86/caget -d
> DBR_STRING swave
> Read operation timed out: some PV data was not read.
> swave
>     *** CA error The requested data transfer is greater than available
> memory or EPICS_CA_MAX_ARRAY_BYTES
> [-bash SLSBASE=/work]$ export EPICS_CA_MAX_ARRAY_BYTES=2621416
> [-bash SLSBASE=/work]$ /usr/local/epics/base/bin/SL5-x86/caget -#10 -d
> DBR_STRING swave
> swave
>     Data type:      DBR_STRING (native: DBF_STRING)
>     Element count:  10
>     Value:
> The reason behind should be answered by experts then.
> Best,
> Xiaoqiang
> From: Ritesh Sugandhi [mailto:[email protected]]
> Sent: Thu 4/21/2011 5:25 PM
> To: Wang Xiaoqiang
> Subject: Handling of String Array in CaChannel library
> Dear Sir,
> thanks for sharing the code,  using your code I have mange to read and
> write
> array a simple array.
> I am able to successfully enhance the code to  read and write a double
> array
> of size 64k ( 65535) elements. in this case I am using
> EPICS_CA_MAX_ARRAY_BYTES configuration was 524280 ( i.e. 65535 * 8 bytes
> for
> double). this works successfully
> I have declared a string Array of 65535 elements and this time I have
> setted
> EPICS_CA_MAX_ARRAY_BYTES to 2621400 (i.e. 40*65535 considering size of 40
> bytes for string) at server and client side. running with this gives error
> $ python2.6 ca-channel-v1.6-demo-waveform-string-64k.py
> ('total values are', 65535)
> The requested data transfer is greater than available memory or
> but when I set EPICS_CA_MAX_ARRAY_BYTES to greater then 26214*20 at client
> side.* I get the correct data at client side.
> code is
> from CaChannel import *
> from random    import *
> def main():
>   try:
>     channel = CaChannel('Py:string64k')
>     channel.searchw()
>     newval=[]
>     for i in range(65535):
> newval.append("ABCDEFGHIJKLMNOPQRSTUVWXYZ0123456789-$#")
>     channel.putw(newval)
>     print('total values are',channel.element_count())
>     print(channel.getw())
>     del channel
>   except CaChannelException, status:
>     print ca.message(status)
> main()
> record is
>  record(waveform, "Py:string64k")
>     field(DESC, "string array")
>     field(NELM, "65535")
>     field(FTVL, "STRING")
> On Wed, Apr 20, 2011 at 4:21 PM, Wang Xiaoqiang
> <[email protected]>wrote:
> > Hi,
> > Load this into your IOC:
> > record(waveform, "cawave")
> >     field(DESC, "numeric array")
> >     field(NELM, "20")
> >     field(FTVL, "DOUBLE")
> > >>> import CaChannel
> > >>> pv=CaChannel.CaChannel('cawave')
> > >>> pv.searchw()
> > >>> pv.getw()
> > [0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0,
> 0.0,
> > 0.0, 0.0, 0.0, 0.0, 0.0]
> > >>> pv.putw(range(12))
> > >>> pv.getw()
> > [0.0, 1.0, 2.0, 3.0, 4.0, 5.0, 6.0, 7.0, 8.0, 9.0, 10.0, 11.0, 0.0, 0.0,
> > 0.0, 0.0, 0.0, 0.0, 0.0, 0.0]
> > Xiaoqiang
> > *From:* [email protected] [mailto:
> > [email protected]] *On Behalf Of *Ritesh Sugandhi
> > *Sent:* Wednesday, April 20, 2011 3:48 PM
> > *To:* [email protected]
> > *Subject:* Handling of Array in CaChannel library
> > Dear Sir,
> > Could I get an example of how to handle sub array and waveforms records
> in
> > CaChannel-v1.6 library code.
> > Best regards,
> > ritesh Sugandhi
Re: Handling of String Array in CaChannel library Matt Newville
Handling of String Array in CaChannel library Ritesh Sugandhi
RE: Handling of String Array in CaChannel library Wang Xiaoqiang
Prev: RE: PyEpics and Python threads Jeff Hill
Next: Re: About ASG usage Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Handling of String Array in CaChannel library Wang Xiaoqiang
Next: Re: Handling of String Array in CaChannel library Matt Newville
