1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Handling of String Array in CaChannel library
To: Jeff Hill <[email protected]>
Date: Mon, 25 Apr 2011 13:30:29 -0500
Hi Jeff, Xiaoqiang, Ritesh,
I was looking at Ritesh's message about array sizes and string arrays.
   For what it's worth, I see slightly different behavior, suggesting
that string arrays require (element_count*40 + 28) bytes. I get the
output below with 3.14.12 on linux-x86 for both ioc (with large
EPICS_CA_MAX_ARRAY_BYTES) and client (with EPICS_CA_MAX_ARRAY_BYTES
varying as shown).
HTH,
--Matt
~>cainfo Py:string2k Py:string64k
Py:string2k
    State:         connected
    Host:          vincent.cars.aps.anl.gov:5064
    Access:        read, write
    Data type:     DBR_STRING (native: DBF_STRING)
    Element count: 2048
Py:string64k
    State:         connected
    Access:        read, write
    Element count: 65536
~>export EPICS_CA_MAX_ARRAY_BYTES=81947 ; caget Py:string2k
Read operation timed out: some PV data was not read.
Py:string2k*** CA error The requested data transfer is greater than
available memory or EPICS_CA_MAX_ARRAY_BYTES
~>export EPICS_CA_MAX_ARRAY_BYTES=81948 ; caget Py:string2k
Py:string2k 2048 ... (succeeds)
~>export EPICS_CA_MAX_ARRAY_BYTES=2621467 ; caget Py:string64k
Py:string64k*** CA error The requested data transfer is greater than
~>export EPICS_CA_MAX_ARRAY_BYTES=2621468 ; caget Py:string64k
Py:string64k 65536 ... (succeeds)
On Thu, Apr 21, 2011 at 6:13 PM, Jeff Hill <[email protected]> wrote:
>> It seems for DBF_STRING array there is certain
>> overhead, 16 bytes, when reading from CA client.
>> In your case, setting EPICS_CA_MAX_ARRAY_BYTES to
>> 2621416 works (but 2621415 didn’t work).
> As I recall, the size of the ca protocol header (16 bytes) _is_ implicitly
> added to the users request in EPICS_CA_MAX_ARRAY_BYTES so that such
> anomalies don’t occur, but perhaps I have neglected to add implicitly
> additional amounts for the larger (by 8 bytes) protocol header emitted when
> the request size is more than 0xffff bytes. Admittedly, this doesn’t yet
> fully explain the 15/16 transition of the issue that you are observing.
> In any case I have created a bug entry so that this issue can be tracked,
> and fixed.
> https://bugs.launchpad.net/epics-base/+bug/768670
> Jeff
> ______________________________________________________
> Jeffrey O. Hill           Email        [email protected]
> LANL MS H820              Voice        505 665 1831
> Los Alamos NM 87545 USA   FAX          505 665 5107
> Message content: TSPA
> With sufficient thrust, pigs fly just fine. However, this is
> not necessarily a good idea. It is hard to be sure where they
> are going to land, and it could be dangerous sitting under them
> as they fly overhead. -- RFC 1925
>> -----Original Message-----
>> From: [email protected] [mailto:[email protected]]
>> On Behalf Of Wang Xiaoqiang
>> Sent: Thursday, April 21, 2011 2:23 PM
>> To: Ritesh Sugandhi
>> Cc: [email protected]
>> Subject: RE: Handling of String Array in CaChannel library
>> Hi,
>> It seems for DBF_STRING array there is certain overhead, 16 bytes, when
>> reading from CA client. In your case, setting EPICS_CA_MAX_ARRAY_BYTES to
>> 2621416 works. I verified with caget from epics base
>> [-bash SLSBASE=/work]$ export EPICS_CA_MAX_ARRAY_BYTES=2621415
>> [-bash SLSBASE=/work]$ /usr/local/epics/base/bin/SL5-x86/caget -d
>> DBR_STRING swave
>> swave
>>     *** CA error The requested data transfer is greater than available
>> [-bash SLSBASE=/work]$ export EPICS_CA_MAX_ARRAY_BYTES=2621416
>> [-bash SLSBASE=/work]$ /usr/local/epics/base/bin/SL5-x86/caget -#10 -d
>> DBR_STRING swave
>> swave
>>     Element count:  10
>>     Value:
>> The reason behind should be answered by experts then.
>> Best,
>> Xiaoqiang
>> From: Ritesh Sugandhi [mailto:[email protected]]
>> Sent: Thu 4/21/2011 5:25 PM
>> To: Wang Xiaoqiang
>> Subject: Handling of String Array in CaChannel library
>> Dear Sir,
>> thanks for sharing the code,  using your code I have mange to read and
>> write
>> array a simple array.
>> I am able to successfully enhance the code to  read and write a double
>> array
>> of size 64k ( 65535) elements. in this case I am using
>> EPICS_CA_MAX_ARRAY_BYTES configuration was 524280 ( i.e. 65535 * 8 bytes
>> for
>> double). this works successfully
>> I have declared a string Array of 65535 elements and this time I have
>> setted
>> EPICS_CA_MAX_ARRAY_BYTES to 2621400 (i.e. 40*65535 considering size of 40
>> bytes for string) at server and client side. running with this gives error
>> $ python2.6 ca-channel-v1.6-demo-waveform-string-64k.py
>> ('total values are', 65535)
>> The requested data transfer is greater than available memory or
>> but when I set EPICS_CA_MAX_ARRAY_BYTES to greater then 26214*20 at client
>> side.* I get the correct data at client side.
>> code is
>> from CaChannel import *
>> from random    import *
>> def main():
>>   try:
>>     channel = CaChannel('Py:string64k')
>>     channel.searchw()
>>     newval=[]
>>     for i in range(65535):
>> newval.append("ABCDEFGHIJKLMNOPQRSTUVWXYZ0123456789-$#")
>>     channel.putw(newval)
>>     print('total values are',channel.element_count())
>>     print(channel.getw())
>>     del channel
>>   except CaChannelException, status:
>>     print ca.message(status)
>> main()
>> record is
>>  record(waveform, "Py:string64k")
>>     field(DESC, "string array")
>>     field(NELM, "65535")
>>     field(FTVL, "STRING")
>> On Wed, Apr 20, 2011 at 4:21 PM, Wang Xiaoqiang
>> <[email protected]>wrote:
>> > Hi,
>> > Load this into your IOC:
>> > record(waveform, "cawave")
>> >     field(DESC, "numeric array")
>> >     field(NELM, "20")
>> >     field(FTVL, "DOUBLE")
>> > >>> import CaChannel
>> > >>> pv=CaChannel.CaChannel('cawave')
>> > >>> pv.searchw()
>> > >>> pv.getw()
>> > [0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0,
>> 0.0,
>> > 0.0, 0.0, 0.0, 0.0, 0.0]
>> > >>> pv.putw(range(12))
>> > >>> pv.getw()
>> > [0.0, 1.0, 2.0, 3.0, 4.0, 5.0, 6.0, 7.0, 8.0, 9.0, 10.0, 11.0, 0.0, 0.0,
>> > 0.0, 0.0, 0.0, 0.0, 0.0, 0.0]
>> > Xiaoqiang
>> > *From:* [email protected] [mailto:
>> > [email protected]] *On Behalf Of *Ritesh Sugandhi
>> > *Sent:* Wednesday, April 20, 2011 3:48 PM
>> > *To:* [email protected]
>> > *Subject:* Handling of Array in CaChannel library
>> > Dear Sir,
>> > Could I get an example of how to handle sub array and waveforms records
>> in
>> > CaChannel-v1.6 library code.
>> > Best regards,
>> > ritesh Sugandhi
Handling of String Array in CaChannel library Ritesh Sugandhi
RE: Handling of String Array in CaChannel library Wang Xiaoqiang
RE: Handling of String Array in CaChannel library Jeff Hill
Prev: Re: PV not found Michael Davidsaver
Next: Re: VMIC VMIVME 4105 register cannot be modified? Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Handling of String Array in CaChannel library Jeff Hill
Next: Memory bank swap feature for SIS3301? Frank Hoeflich
