1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: PyEpics and Python threads
To: "'Andrew Johnson'" <[email protected]>, "'Matt Newville'" <[email protected]>
Cc: "'Vigder, Mark'" <[email protected]>, [email protected]
Date: Thu, 21 Apr 2011 16:54:11 -0600
> However unless you use the epicsThread routines in libCom
> to create that thread I don't believe it will have any way
> to clean up the context again when that thread exits
The R3.14 ca library, will implicitly create a ca context for the thread
that does not call ca_create_context before it uses ca functions, but in
fact it will not implicitly destroy that context when the thread exits. That
step must be performed manually, by calling ca_destroy_context. This
behavior is invariant of whether the thread was created by the epicsThread
routines or not.
BTW: The implicit creation of a ca context is a side effect of the library
API's remaining backwards compatible with the original single threaded,
single context, implementation.
It's hard to guess if there will ever be a valid need for multiple contexts
in one python program, but perhaps it would be a mistake to preclude that
possibility. Multiple contexts are used in the IOC, for example, to maintain
independence between the database ca links and the sequencer ca variables.
Jeff
______________________________________________________
Jeffrey O. Hill           Email        [email protected]
LANL MS H820              Voice        505 665 1831
Los Alamos NM 87545 USA   FAX          505 665 5107
Message content: TSPA
With sufficient thrust, pigs fly just fine. However, this is
not necessarily a good idea. It is hard to be sure where they
are going to land, and it could be dangerous sitting under them
as they fly overhead. -- RFC 1925
> -----Original Message-----
> From: [email protected] [mailto:tech-talk-
> [email protected]] On Behalf Of Andrew Johnson
> Sent: Thursday, April 21, 2011 3:39 PM
> To: Matt Newville
> Cc: Vigder, Mark; [email protected]
> Subject: Re: PyEpics and Python threads
> Hi Matt,
> On Thursday 21 April 2011 15:17:59 Matt Newville wrote:
> > I find that if I create channels inside Python threads they do have
> > new contexts (that is other than the initial one), even without
> > asking.  Doing
> >    ca_create_context(); create-and-use-channels ; ca_context_destroy()
> > within a thread seems to work fine.
> CA will automatically create a new context if it finds that the thread
> it's
> running in doesn't have one already defined.  However unless you use the
> epicsThread routines in libCom to create that thread I don't believe it
> will
> have any way to clean up the context again when that thread exits, so
> wrapping
> the create-and-use-channels code with ca_create_context() and
> ca_context_destroy() like you show above is probably necessary unless the
> process is short-lived or about to die anyway.
> > In order to have all processing done in one context, I have to
> > explicitly get the initial context in the main thread, and pass this
> > into each thread.  That seems like extra work for the user.   If
> > that's the recommendation,  would it be reasonable to have ca.py make
> > sure to attach to the initial context (if needed) prior to any
> > processing?
> That's what I'm suggesting; you would run ca_create_context() once in the
> PyEpics library initialization and store the value from
> ca_current_context()
> into a global or module variable.  The tricky thing is that for
> performance
> reasons you'd rather not have to check whether the context is set for the
> current thread (or explicitly reattach to the main context) every time
> you
> make a CA call.  That's where Mark's suggestion of sub-classing the
> python
> threading.Thread class might help, in that it would call
> ca_attach_context()
> once at thread start-up and you'd never need to worry about it again.
> However
> anyone who doesn't use your thread creation code could end up creating a
> new
> CA context and getting weird behavior, so you'd need to document that
> issue
> and provide them with a way to attach other threads to your shared
> context
> anyway.
> > Is there a use-case for multiple contexts on the client side?
> Very rarely, such that I think you could ignore the possibility and force
> all
> threads into a single shared context.  However the nice thing about
> relying on
> thread start-up (or the user's code) to do the attach is that it should
> run
> slightly faster and still permit user code to create a new context and
> attach
> specific threads to that instead of the main context if the developer
> wants to
> do that.
> HTH,
> - Andrew
> An error is only a mistake if you don't learn from it.
> When you learn something from it, it becomes a lesson.
Re: PyEpics and Python threads Andrew Johnson
PyEpics and Python threads Vigder, Mark
Re: PyEpics and Python threads Matt Newville
Prev: Re: PyEpics and Python threads Andrew Johnson
Next: RE: Handling of String Array in CaChannel library Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: PyEpics and Python threads Andrew Johnson
