1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: PyEpics and Python threads
To: "Jeff Hill" <[email protected]>
Cc: [email protected]
Date: Fri, 22 Apr 2011 10:09:22 -0500
Hi Jeff,
On Thursday 21 April 2011 17:54:11 Jeff Hill wrote:
> > However unless you use the epicsThread routines in libCom
> > to create that thread I don't believe it will have any way
> > to clean up the context again when that thread exits
> The R3.14 ca library, will implicitly create a ca context for the thread
> that does not call ca_create_context before it uses ca functions, but in
> fact it will not implicitly destroy that context when the thread exits.
Ah, I thought you might be registering an epicsAtThreadExit() handler and keep
a reference count on the number of threads using each context, but on
reflection I see that would be a rather brittle approach since an application
could be managing its own contexts privately without you knowing about it.
Thanks for the clarification,
- Andrew
An error is only a mistake if you don't learn from it.
When you learn something from it, it becomes a lesson.
PyEpics and Python threads Vigder, Mark
Re: PyEpics and Python threads Andrew Johnson
RE: PyEpics and Python threads Jeff Hill
Prev: Re: #RE: About ASG usage jun-ichi.odagiri
Next: VMIC VMIVME 4105 register cannot be modified? 马晓媛
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: PyEpics and Python threads Jeff Hill
Next: EPICS Base v3.14.12.1-rc1 compilation error Ritesh Sugandhi
