1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: PyEpics and Python threads
Date: Wed, 20 Apr 2011 14:04:08 -0400
I'm working on getting PyEpics and Python threads to work together. I get a lot of
inconsistent behaviour, but the following seems to be somewhat consistent. At least
today it is. I have a motor record, 'L3:m1' and run the following:
from threading import Thread
import epics
import random
def th(pv, sp):
    epics.ca.context_create()
    pv.put(sp, wait=True)
    epics.ca.context_destroy()
if __name__ == '__main__':
        d1=random.randrange(360)
        m = epics.PV('L3:m1')
        t1 = Thread(target=th, args=(m, d1))
        t1.start()
When executing the 'pv.put' statement, this (almost) always sits for about 30 seconds
doing nothing, and then moves the motor correctly. Why the 30 second delay?
However, the following program usually (though not always) executes correctly
without the 30 second delay.
import epics
import random
def th(pv, sp):
        anyPV = epics.PV('L3:scan1')
        t1.start()
The only difference is I created some arbitrary unrelated PV before starting the thread. I'm still
trying to understand CA contexts, so I'm not sure those calls are necessary, but
for some things I tried they seemed to be required. Other little changes, such as creating the
PV object inside the thread rather than passing it in to the thread, also seem to eliminate the 30 second delay.
Trying on my PC rather than linux co-hosted with IOC gives about a 10 second delay.
Any help or explanations are well appreciated.
Mark Vigder
Canadian Neutron Beam Centre
Re: PyEpics and Python threads Matt Newville
Prev: Re: status of Debian/Ubuntu packages/repositories Andrew Johnson
Next: Re: status of Debian/Ubuntu packages/repositories Michael Davidsaver
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: creating Deb/RPM packages (with CMake) Martin Konrad
Next: Re: PyEpics and Python threads Matt Newville
