1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: creating Deb/RPM packages (with CMake)
To: [email protected]
Date: Thu, 21 Apr 2011 01:23:13 +0200
I'm using Michaels packages, too.
> Our build system wasn't designed with the needs of distro
> packaging in mind, but we are slowly moving in the direction of making
> that possible.
CMake provides a very clean way to cross-build as well as package for different
platforms (mainly because you get out-of-tree builds for free). That's why
there already has been some discussion about CMake last year. Michael
published his CMake files for building base here:
https://code.launchpad.net/~mdavidsaver/epics-base/cmake
I am using CMake to build a device support (because it uses several libraries
that are much easier to find and use from CMake). I'm still using the
traditional Makefile approach for my IOC.
In the last weeks support for packaging CMake components into different deb/rpm
files was added to CPack. This means that you can now easily create several
deb/rpm files from one source tree (e.g. one for each of applications,
libraries, and headers). It is even possible to derive the dependencies
between deb packages from the dependencies between the components
automatically. Support for this is coming with CMake 2.8.5 which will be
released next week.
Cheers
Martin
Dipl. Phys. Martin Konrad
Technische Universität Darmstadt
Institut für Kernphysik
Schlossgartenstr. 9
64289 Darmstadt
Tel: +49-6151-16-5121
Fax: +49-6151-16-4321
status of Debian/Ubuntu packages/repositories Jameson Graef Rollins
Prev: RE: PyEpics and Python threads Vigder, Mark
Next: Re: PyEpics and Python threads Matt Newville
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: status of Debian/Ubuntu packages/repositories Bill Lavender
Next: PyEpics and Python threads Vigder, Mark
