1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: PyEpics and Python threads
To: "Vigder, Mark" <[email protected]>
Date: Wed, 20 Apr 2011 21:36:25 -0500
Hi Mark, Andrew,
There are ca.context_create(), ca.context_destroy(),
ca.attach_context() functions that go directly to the C library
functions.
In all (both) examples I had of using put() with threads, a new
context was explicitly created, then PVs were created and used within
that thread, and finally the context was destroyed.
Andrews suggestion of attaching to the "main thread" context works
too.  I think there is a mistake in ca.py, as
ca.attach_context(context) raises an exception if the return value
from ca_attach_context() is not ECA_ISATTACHED (I think I read the doc
incorrectly -- I get ECA_NORMAL).  I pushed the change to ca.py to run
PySEVCHK expecting expect ECA_NORMAL instead of ECA_ISATTACHED to
github.  Ignoring that bug for now, attaching to the existing context
like this does work:
import time, epics, threading
def threaded_putwait(pv, context, value):
    "put-with-wait for calling in a thread"
    t0 = time.time()
    try:
        epics.ca.attach_context(context)
    except:
        pass
    pv.put(value, wait=True, timeout=10.0)
    print ' - threaded_putwait done (%.3f sec)' % (time.time()-t0)
if __name__ == '__main__':
    pvname = 'XXX.VAL'
    target = 10
    pv = epics.PV(pvname)
    pv.put(-target, wait=True)
    context = epics.ca.current_context()
    th = threading.Thread(target=threaded_putwait,
                          args=(pv, context, target))
    th.start()
    th.join()
    print 'All Done.'
Mark, is that approximately what you found as well?
Perhaps it would be better for a PV to save its context at creation,
and automatically know to switch to its context before doing any work?
 That would make the saving and attaching of the context in the above
script unnecessary, so that "plain looking" code could more easily be
made multi-threaded without having to worry about contexts.   I'm not
sure what the negative consequences of that would be.
--Matt Newville
RE: PyEpics and Python threads Vigder, Mark
Re: PyEpics and Python threads Matt Newville
Re: PyEpics and Python threads Andrew Johnson
Prev: creating Deb/RPM packages (with CMake) Martin Konrad
Next: Re: ca.py - Throws error - workaround Luca Luisa
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: PyEpics and Python threads Vigder, Mark
Next: RE: PyEpics and Python threads Vigder, Mark
