1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: PyEpics and Python threads
To: Matt Newville <[email protected]>, "Vigder, Mark" <[email protected]>
Cc: [email protected]
Date: Wed, 20 Apr 2011 15:45:43 -0500
Hi Matt & Mark,
On Wednesday 20 April 2011 15:06:33 Matt Newville wrote:
> On Wed, Apr 20, 2011 at 1:04 PM, Vigder, Mark
> <[email protected]> wrote:
> > The only difference is I created some arbitrary unrelated PV before
> > starting the thread. I'm still
> > trying to understand CA contexts, so I'm not sure those calls are
> > necessary, but
> > for some things I tried they seemed to be required. Other little changes,
> > such as creating the
> > PV object inside the thread rather than passing it in to the thread, also
> > seem to eliminate the 30 second delay.
> > Trying on my PC rather than linux co-hosted with IOC gives about a 10
> > second delay.
> > Any help or explanations are well appreciated.
> The default timeout for pv.put() in "put-with-wait" mode is 30
> seconds, which is probably where that time is coming from.
> It appears that the put-with-wait is not announcing completeness
> across "contexts" (that is you create a PV in the main thread, then
> create a new context in the created thread and do the put-with-wait on
> the PV from the original thread).  It's possible thatt the
> put-with-wait is not complete enough for dealing with all thread cases
> right now.
Assuming that epics.ca.context_create() results in a call to
ca_context_create() then I worry that Mark's code ends up trying to use a chid
created in one CA context (associated with the object m) in a thread that is
running with a different CA context.  Internally a chid has a reference to the
context it was created in, and I have no idea what happens if you use one this
way, but I'm fairly sure you're not supposed to.
I would recommend that you share a single CA context across all the threads in
your program unless you have a very good reason to not do that, it saves
resources.  To do that you'll need to find out what the PyEpics equivalents
are of the routines ca_current_context() and ca_attach_context(), and pass the
context pointer returned by calling ca_current_context() from the main thread
into the new thread and there passing it to ca_attach_context().
HTH,
- Andrew
An error is only a mistake if you don't learn from it.
When you learn something from it, it becomes a lesson.
RE: PyEpics and Python threads Vigder, Mark
Re: PyEpics and Python threads Matt Newville
Prev: Re: status of Debian/Ubuntu packages/repositories Bill Lavender
Next: RE: PyEpics and Python threads Vigder, Mark
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: PyEpics and Python threads Matt Newville
