1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: PyEpics and Python threads
Date: Thu, 21 Apr 2011 10:12:12 -0400
Matt
I did exactly as you suggested below. I assumed that the exception
being returned was a mistake. I'll pull the latest version with
the fix.
Another option for making the code more "plain looking" is to
use a single CA context and subclass Python's threading.Thread.
This subclass can be used for creating threads in PyEpics and
the subclass could switch to the single context in use. This
of course only works if there is a single context for the
application.
This is the first time I've had to deal with CA contexts, and
I must admit I don't understand them yet - why they exist,
when they get switched, or if one might want to have multiple
contexts with PV's defined within different contexts. Time to
hit the manuals.
On April 20, 2011 10:36 PM Matt Newville wrote
>I think there is a mistake in ca.py, as
>ca.attach_context(context) raises an exception if the return value
>from ca_attach_context() is not ECA_ISATTACHED (I think I read the doc
>incorrectly -- I get ECA_NORMAL).  I pushed the change to ca.py to run
>PySEVCHK expecting expect ECA_NORMAL instead of ECA_ISATTACHED to
>github.  Ignoring that bug for now, attaching to the existing context
>like this does work:
>import time, epics, threading
>def threaded_putwait(pv, context, value):
>    "put-with-wait for calling in a thread"
>    t0 = time.time()
>    try:
>        epics.ca.attach_context(context)
>    except:
>        pass
>    pv.put(value, wait=True, timeout=10.0)
>    print ' - threaded_putwait done (%.3f sec)' % (time.time()-t0)
>if __name__ == '__main__':
>    pvname = 'XXX.VAL'
>    target = 10
>    pv = epics.PV(pvname)
>    pv.put(-target, wait=True)
>    context = epics.ca.current_context()
>    th = threading.Thread(target=threaded_putwait,
>                          args=(pv, context, target))
>    th.start()
>    th.join()
>    print 'All Done.'
>Mark, is that approximately what you found as well?
>Perhaps it would be better for a PV to save its context at creation,
>and automatically know to switch to its context before doing any work?
> That would make the saving and attaching of the context in the above
>script unnecessary, so that "plain looking" code could more easily be
>made multi-threaded without having to worry about contexts.   I'm not
>sure what the negative consequences of that would be.
>--Matt Newville
Re: PyEpics and Python threads Matt Newville
PyEpics and Python threads Vigder, Mark
Re: PyEpics and Python threads Andrew Johnson
RE: PyEpics and Python threads Vigder, Mark
Prev: RE: shell command arguments limitation? Jim Chen
Next: Re: EPICS Base v3.14.12.1-rc1 compilation error Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: PyEpics and Python threads Matt Newville
Next: Re: PyEpics and Python threads Matt Newville
