You need to edit CONFIG_SITE.Common.linux-x86_64 and comment the
COMMANDLINE_LIBRARY = READLINE
line and uncomment the correct line:
COMMANDLINE_LIBRARY = READLINE_NCURSES
as described in the preceding comment:
# Depending on your version of Linux you'll want one of the following
# lines to enable command-line editing and history in iocsh. If you're
# not sure which, start with the top one and work downwards until the
# build doesn't fail to link the readline library. If none of them work,
# comment them all out to build without readline support.
On Apr 21, 2011, at 2:46 AM, Ritesh Sugandhi wrote:
> Dear Sir,
> I am trying to compile EPICS Base v3.14.12.1-rc1 on Linux ( kernal 2.6.18-194.8.1 x86-64 bit ; gcc (GCC) 4.1.2 ) on 64 bit machine
> During compilation , I get following message
> /usr/bin/g++ -o antelope -L/home/ITER/sugandr/base-3.14.12.1-rc1/lib/linux-x86_64 -Wl,-rpath,/home/ITER/sugandr/base-3.14.12.1-rc1/lib/linux-x86_64 -m64 closure.o error.o lalr.o lr0.o main.o mkpar.o output.o reader.o skeleton.o symtab.o verbose.o warshall.o -lCom
> /usr/lib64/libreadline.so.5: undefined reference to `PC'
> /usr/lib64/libreadline.so.5: undefined reference to `tgetflag'
> /usr/lib64/libreadline.so.5: undefined reference to `tgetent'
> /usr/lib64/libreadline.so.5: undefined reference to `UP'
> /usr/lib64/libreadline.so.5: undefined reference to `tputs'
> /usr/lib64/libreadline.so.5: undefined reference to `tgoto'
> /usr/lib64/libreadline.so.5: undefined reference to `tgetnum'
> /usr/lib64/libreadline.so.5: undefined reference to `BC'
> /usr/lib64/libreadline.so.5: undefined reference to `tgetstr'
> collect2: ld returned 1 exit status
> I tried to look at libreadline library
> $ ls /usr/lib64/libreadline*
> /usr/lib64/libreadline.a /usr/lib64/libreadline.so /usr/lib64/libreadline.so.5 /usr/lib64/libreadline.so.5.1
> seeking help and suggestions,
> Thanking you,
> Best Regards,
> Ritesh Sugandhi
Eric Norum
[email protected]
- EPICS Base v3.14.12.1-rc1 compilation error Ritesh Sugandhi
RE: PyEpics and Python threads Vigder, Mark
Re: EPICS Base v3.14.12.1-rc1 compilation error Andrew Johnson
<2011>
2025
2026
<2011>
2025
2026
