1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS Base v3.14.12.1-rc1 compilation error
To: [email protected]
Date: Thu, 21 Apr 2011 10:21:04 -0500
Hi Ritesh,
On Thursday 21 April 2011 04:46:24 Ritesh Sugandhi wrote:
> During compilation , I get following message
> /usr/bin/g++ -o antelope
> -L/home/ITER/sugandr/base-3.14.12.1-rc1/lib/linux-x86_64
> -Wl,-rpath,/home/ITER/sugandr/base-3.14.12.1-rc1/lib/linux-x86_64
> -m64                closure.o error.o lalr.o lr0.o main.o mkpar.o output.o
> reader.o skeleton.o symtab.o verbose.o warshall.o   -lCom
> /usr/lib64/libreadline.so.5: undefined reference to `PC'
> /usr/lib64/libreadline.so.5: undefined reference to `tgetflag'
> /usr/lib64/libreadline.so.5: undefined reference to `tgetent'
> /usr/lib64/libreadline.so.5: undefined reference to `UP'
> /usr/lib64/libreadline.so.5: undefined reference to `tputs'
> /usr/lib64/libreadline.so.5: undefined reference to `tgoto'
> /usr/lib64/libreadline.so.5: undefined reference to `tgetnum'
> /usr/lib64/libreadline.so.5: undefined reference to `BC'
> /usr/lib64/libreadline.so.5: undefined reference to `tgetstr'
> collect2: ld returned 1 exit status
Your version of Linux requires EPICS binaries (which use readline by default
on Linux) to be linked with another library, most probably libncurses.  You
configure that by editing configure/os/CONFIG_SITE.Common.linux-x86_64 and
changing the setting for COMMANDLINE_LIBRARY to READLINE_NCURSES or possibly
READLINE_CURSES (see the comments in that file).  The different Linux
distributions need different settings so we can't make the default work for
everyone.
Note that you will probably have to completely rebuild base ("make rebuild"
from the top directory) after changing that setting.
- Andrew
An error is only a mistake if you don't learn from it.
When you learn something from it, it becomes a lesson.
EPICS Base v3.14.12.1-rc1 compilation error Ritesh Sugandhi
Prev: Re: EPICS Base v3.14.12.1-rc1 compilation error Eric Norum
Next: Handling of String Array in CaChannel library Ritesh Sugandhi
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: About ASG usage jun-ichi.odagiri
