1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: shell command arguments limitation?
To: "'Mark Rivers'" <[email protected]>, "'Andrew Johnson'" <[email protected]>, <[email protected]>
Cc: "'Eric Norum'" <[email protected]>
Date: Thu, 21 Apr 2011 13:41:48 +0100
Yes Mark, that does do the job. Yet one side effect is that I couldn't pass
VxWorks symbols (such as IPAC3) to my shell command any more, although I can
manually manage the example IPAC3
IPAC3 = ipacAddHy8002("3,2")
iocsh()
epics> Hy8417AsynInit("ADC8417", IPAC3, 1, 10, 1000, 1, 1, 0, 9, 0, 0, 0,
16, 16)
illegal integer 'IPAC3'
I have to do
epics> Hy8417AsynInit("ADC8417", 0, 1, 10, 1000, 1, 1, 0, 9, 0, 0, 0, 16,
16)
and it works fine.
Jim
Hytec Electronics Ltd.
Tel: +44 (0) 118 975 7770
Fax: +44 (0) 118 975 7566
Web: www.hytec-electronics.co.uk
Incorporated in England No 1246940
VAT NO GB 285 2479 27
> -----Original Message-----
> From: Mark Rivers [mailto:[email protected]]
> Sent: 21 April 2011 12:03
> To: Jim Chen; Andrew Johnson; [email protected]
> Cc: Eric Norum
> Hi Jim,
> I think the vxWorks shell is limited to 10 arguments to function calls.
> However, it should work to run iocsh under vWorks, and then you won't
> have the limit.
> Try adding a call to iocsh before your call to the 14 argument command.
> Mark
> ________________________________
> From: [email protected] on behalf of Jim Chen
> Sent: Thu 4/21/2011 5:39 AM
> To: 'Andrew Johnson'; [email protected]
> Cc: 'Eric Norum'
> Thanks for all the comments.
> I have a configuration which takes 14 arguments to the shell command
> and
> here is the start up printouts:
> # For VME/VxWorks
> new symbol "IPAC3" added to symbol table.
> IPAC3 = 0x1ed56080: value = 0 = 0x0
> #int Hy8417AsynInit(char *portName, int vmeSlotNum, int ipSlotNum, int
> vectorNum,
> #                                       int samples, int average, int
> mode,
> int offset, int clockRate,
> #                   int extClock, int fastADC, int range, int ChannelNo,
> int
> ChannelBit)
> # Settings are:
> #       vmeslot=0, ipslot=5, vector=10, samples=1000, average=1,
> mode=1(trigger), offset=0,
> #   clockrate=9(1kHz), extclock=0(no), fastADC=0(slow mca & EPID),
> range=0(+/-10V),
> #       ChannelNo=16, ChannelBit=16
> Hy8417AsynInit("ADC8417", IPAC3, 1, 10, 1000, 1, 1, 0, 9, 0, 0, 0, 16,
> 16)
> too many arguments to functions.
> Done executing startup script /localhome/local/st.cmd
> It complains about "too many arguments to functions."
> Interestingly, it doesn't complain in my Linux box.
> I remember few years ago we had similar situation with about 18
> arguments in
> a configuration routine, we ended up splitting them into two with the
> first
> one taking 12 and it works fine since.
> The test environment: VxWorks 5.5, processor board MVME5500, EPICS
> 3.14.8.2.
> Any ideas please?
> Jim
> > From: [email protected] [mailto:tech-talk-
> > [email protected]] On Behalf Of Andrew Johnson
> > Sent: 20 April 2011 18:18
> > To: [email protected]
> > Cc: Eric Norum
> > Subject: Re: shell command arguments limitation?
> > On Wednesday 20 April 2011 12:02:31 Eric Norum wrote:
> > > The ioc shell doesn't call its registered functions with individual
> > >  arguments so the limit you're describing does not exist.  iocsh
> > handler
> > >  functions are called with a single argument -- a pointer to an
> array
> > of
> > >  argument unions.  The only limit that I can see is the amount of
> > memory
> > >  available to hold this array.
> > There may be a limit to the length of the command line buffer which
> > would
> > restrict the number of arguments, but that probably depends on the
> > underlying
> > OS and what the EPICS_READLINE setting is.
> > Jim may have been remembering the arguments to the vxWorks taskSpawn()
> > function, which is limited to 10 arguments.  I'm not aware of a limit
> > in the
> > vxWorks shell either, but there may be one that I haven't come across
> > yet.
> > - Andrew
> > An error is only a mistake if you don't learn from it.
> > When you learn something from it, it becomes a lesson.
New sequencer bugfix release candidate Benjamin Franksen
RE: shell command arguments limitation? Hu, Yong
Re: shell command arguments limitation? Eric Norum
Re: shell command arguments limitation? Andrew Johnson
RE: shell command arguments limitation? Jim Chen
RE: shell command arguments limitation? Mark Rivers
Prev: RE: shell command arguments limitation? Mark Rivers
Next: RE: PyEpics and Python threads Vigder, Mark
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: shell command arguments limitation? Daron Chabot
