Hi Jim,
I think the vxWorks shell is limited to 10 arguments to function calls.
However, it should work to run iocsh under vWorks, and then you won't have the limit.
Try adding a call to iocsh before your call to the 14 argument command.
Sent: Thu 4/21/2011 5:39 AM
To: 'Andrew Johnson'; [email protected]
Cc: 'Eric Norum'
Subject: RE: shell command arguments limitation?
Thanks for all the comments.
I have a configuration which takes 14 arguments to the shell command and
here is the start up printouts:
# For VME/VxWorks
IPAC3 = ipacAddHy8002("3,2")
new symbol "IPAC3" added to symbol table.
IPAC3 = 0x1ed56080: value = 0 = 0x0
#int Hy8417AsynInit(char *portName, int vmeSlotNum, int ipSlotNum, int
vectorNum,
# int samples, int average, int mode,
int offset, int clockRate,
# int extClock, int fastADC, int range, int ChannelNo, int
ChannelBit)
# Settings are:
# vmeslot=0, ipslot=5, vector=10, samples=1000, average=1,
mode=1(trigger), offset=0,
# clockrate=9(1kHz), extclock=0(no), fastADC=0(slow mca & EPID),
range=0(+/-10V),
# ChannelNo=16, ChannelBit=16
Hy8417AsynInit("ADC8417", IPAC3, 1, 10, 1000, 1, 1, 0, 9, 0, 0, 0, 16, 16)
too many arguments to functions.
Done executing startup script /localhome/local/st.cmd
It complains about "too many arguments to functions."
Interestingly, it doesn't complain in my Linux box.
I remember few years ago we had similar situation with about 18 arguments in
a configuration routine, we ended up splitting them into two with the first
one taking 12 and it works fine since.
The test environment: VxWorks 5.5, processor board MVME5500, EPICS 3.14.8.2.
Any ideas please?
Jim
Hytec Electronics Ltd.
Tel: +44 (0) 118 975 7770
Fax: +44 (0) 118 975 7566
Web: www.hytec-electronics.co.uk
Incorporated in England No 1246940
VAT NO GB 285 2479 27
> -----Original Message-----
> From: [email protected] [mailto:tech-talk-
> [email protected]] On Behalf Of Andrew Johnson
> Sent: 20 April 2011 18:18
> To: [email protected]
> Cc: Eric Norum
> Subject: Re: shell command arguments limitation?
> On Wednesday 20 April 2011 12:02:31 Eric Norum wrote:
> > The ioc shell doesn't call its registered functions with individual
> > arguments so the limit you're describing does not exist. iocsh
> handler
> > functions are called with a single argument -- a pointer to an array
> of
> > argument unions. The only limit that I can see is the amount of
> memory
> > available to hold this array.
> There may be a limit to the length of the command line buffer which
> would
> restrict the number of arguments, but that probably depends on the
> underlying
> OS and what the EPICS_READLINE setting is.
> Jim may have been remembering the arguments to the vxWorks taskSpawn()
> function, which is limited to 10 arguments. I'm not aware of a limit
> in the
> vxWorks shell either, but there may be one that I haven't come across
> yet.
> - Andrew
> An error is only a mistake if you don't learn from it.
> When you learn something from it, it becomes a lesson.
- RE: shell command arguments limitation? Jim Chen
- New sequencer bugfix release candidate Benjamin Franksen
- RE: shell command arguments limitation? Hu, Yong
- Re: shell command arguments limitation? Eric Norum
- Re: shell command arguments limitation? Andrew Johnson
<2011>
2025
2026
<2011>
2025
2026
