1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Re: VMIC VMIVME 4105 register cannot be modified?
To: "Andrew Johnson" <[email protected]>
Cc: [email protected]
Date: Tue, 26 Apr 2011 11:09:12 +0800 (CST)
Thank you!
The information you maybe need:
CPU board: Motorola MVME 5100
OS :       VxWorks 5.4
EPICS:     3.13.8
driver:    I modified the driver of VMIVME 4100 coded by Bob Dalesio
( I didn't modified the driver much, which mainly about some configuration information,like channels number, data structure info and so on.)
I configure one 4105 board in an EPICS application's start-up file--st.cmd.
Code like: vmi4105_cnfg(0,0x0000)
Then I download the application on the vxWorks oprating on the MVME 5100 CPU board.
It return OK. 4105 was configured correctly.
Then I display the register on the board:
-> d 0xfbff0000
fbff0000:  00ff 00ff 00ff 00ff 00ff 00ff 00ff 00ff   *................*
fbff0010:  ffff ffff ffff ffff ffff ffff ffff ffff   *................*
fbff0020:  ffff ffff ffff ffff ffff ffff ffff ffff   *................*
------OK
-> m 0xfbff0000
fbff0000:  00ff-c300  (I only modified first byes.)
fbff0002:  c3ff-.
value = 1 = 0x1  (1 means read-only?)
-> d 0xfbff0000
fbff0000:  c3ff c3ff c3ff c3ff c3ff c3ff c3ff c3ff   *................*  (All of them was modified.)
-------(c3 was the basic configuration. The lower 8bits was reserved, and they cannot be wrote to 0)
-> m 0xfbff0000
fbff0000:  c3ff-74bb  ( D15 is 0, 4bbb is the channel signal)
fbff0002:  c3ff-6bbb  ( D15 is 0, bbb is the channel signal)
fbff0004:  c3ff-.
value = 1 = 0x1
-> d 0xfbff0000
---------As you see, They are not modified, even if I input all the 8 channels signals.)
---------Why??
---------But,it could be wrote to other configure information.
-> m 0xfbff0000
fbff0000:  c3ff-8bbb
fbff0002:  8bff-.
value = 1 = 0x1
-> d 0xfbff0000
fbff0000:  8bff 8bff 8bff 8bff 8bff 8bff 8bff 8bff   *................*
Above shows the errors I come across.
Besides, 4105 has an address modifier response jumper JA.The DAC board is memory mapped in the short I/O address space .To select non-privileged short I/O Access, install jumper at JA.
My board is installed jumper JA.---non-privileged short I/O Access.
The code in driver: status = sysBusToLocalAdrs(VME_AM_SUP_SHORT_IO ,(char *)addr,(char **)&pcard);
( addr is the address I input. pcard returns the local address.)
In sysBusToLocalAdrs, I select VME_AM_SUP_SHORT_IO Address Modifier code.
So, it seems that the hardware configuration and software configuration is inconsistent.But it works well.
I tried remove the jumper of JA, so board response to supervisory short I/O access. But it cannot be configured. 4105 board cannot be found.
I don't know where the errors happened and I don't have idea about the next steps I can try.
I'm looking forward to your response. Thank you very much. ^_^
Ma Xiao yuan
> -----Origin email-----
> From: "Andrew Johnson" <[email protected]>
> Sent Time: Tuesday, April 26, 2011
> To: [email protected]
> Cc: "马晓媛" <[email protected]>
> Subject: Re: VMIC VMIVME 4105 register cannot be modified?
> Hi,
> On Sunday 24 April 2011 22:26:44 马晓媛 wrote:
> > I worked with VMIVME 4105, but now it comes across some problem that I
> >  cannot handle.VMIVME 4105 is a 8channel 12bits multiplying DAC board. I
> >  modified the driver of VMIVME 4100 to 4105's driver. VMIVME 4100 is a
> >  16channel 12bit DAC board. They are alike.
> > Now I can configure the CSR, BUT, I cannot write D15 to "0" to write data
> >  to DAC channels. Why? I need your help. Thank you very much!^_^
> When you say you cannot do that, what actually happens when you try writing a
> 16-bit value with D15=0 to one of the DAC OUT registers?
> Please copy & paste and command you're using and the error messages you see
> directly from the system console, and include more information rather than
> less if you're not sure what might be relevant.  You should also explain what
> CPU board, OS version and driver you are using.  We can't help you very much
> without knowing more about what you are doing.
> - Andrew
> An error is only a mistake if you don't learn from it.
> When you learn something from it, it becomes a lesson.
Re: VMIC VMIVME 4105 register cannot be modified? Andrew Johnson
Re: Re: VMIC VMIVME 4105 register cannot be modified? 马晓媛
Prev: Re: PV not found 闫芬
Next: Re: gateway aborted by SIGBUS Martin L. Smith
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: VMIC VMIVME 4105 register cannot be modified? Andrew Johnson
Next: Re: VMIC VMIVME 4105 register cannot be modified? Andrew Johnson
