1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: regarding CaChannel v1.6 handling of dynamic subarrays
To: [email protected]
Date: Thu, 28 Apr 2011 14:30:59 +0200
Dear sir
I am having a array of double consist of 64 elements and connected to 4 sub-arrays of size 16. I assigned the random numbers to main array . now when I take elements count for each subarray array and display its output. I got each sub-array is assigned with the 64 elements (instead of 16) and appended by 0 at the end elements .
The code output and database schema is included in mail. Please correct if my understanding is not correct.
Thanking you and Best regards,
Ritesh Sugandhi
Output is as below::
(64, [0.15680341096341543, …0.27939076994606538])
('subarrays = 1', 64, [0.15680341096341543,…, 0.6660663007380897,0.0,…. 0.0])
('subarrays = 2', 64, [0.87466558395868221,… 0.59892465207930756, 0.0,  …., 0.0])
('subarrays = 3', 64, [0.20673443822330728,…., 0.34672371303892258, 0.0,… 0.0])
('subarrays = 4', 64, [0.47304895704158478,…, 0.27939076994606538, 0.0, ….0.0])
[sugandr@trunk pydev]$
code is as below::
from CaChannel import *
import random
driver = CaChannel()
driver.searchw('Py:wave_test')
sub1   = CaChannel()
sub1.searchw('Py:subArr1')
sub2   = CaChannel()
sub2.searchw('Py:subArr2')
sub3   = CaChannel()
sub3.searchw('Py:subArr3')
sub4   = CaChannel()
sub4.searchw('Py:subArr4')
#put randome number in driver
driver.putw([random.random() for x in range(64)])
print(driver.element_count(), driver.getw())
print('subarrays = 1', sub1.element_count(),sub1.getw())
print('subarrays = 2', sub1.element_count(),sub2.getw())
print('subarrays = 3', sub1.element_count(),sub3.getw())
print('subarrays = 4', sub1.element_count(),sub4.getw())
EPICS environment is 3.14.12 and RHEL 5.5  64 bit version using CaChannel v1.6 library
Data base schema is
record(subArray, "$(P)subArr1") {
  field(NELM, "16")
  field(INP, "$(P)wave_test.VAL")
  field(INDX, "0")
  field(FTVL, "DOUBLE")
  field(MALM, "64")
record(subArray, "$(P)subArr2") {
  field(NELM, "16")
  field(INDX, "16")
  field(MALM, "64")
record(subArray, "$(P)subArr3") {
  field(NELM, "16")
  field(INDX, "32")
  field(MALM, "64")
record(subArray, "$(P)subArr4") {
  field(NELM, "16")
  field(INDX, "48")
  field(MALM, "64")
record(fanout, "$(P)mylinker") {
  field(FLNK, "$(P)subArr1")
  field(LNK1, "$(P)subArr3")
  field(LNK2, "$(P)subArr2")
  field(LNK3, "$(P)subArr4")
record(waveform, "$(P)wave_test") {
  field(NELM, "64")
  field(EGU, "Counts")
  field(SCAN, "Passive")
  field(FLNK, "$(P)mylinker")
Re: regarding CaChannel v1.6 handling of dynamic subarrays Martin L. Smith
Prev: Handling of a character waveform of 64k elements Ritesh Sugandhi
Next: Re: regarding CaChannel v1.6 handling of dynamic subarrays Martin L. Smith
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Handling of a character waveform of 64k elements Andrew Johnson
