1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS task watch dog
To: "Szalata, Zenon M." <[email protected]>
Date: Sun, 1 May 2011 20:19:59 -0700
I think that you would be better off converting everything over to use the EPICS API -- epicsThreadCreate(...)and such.
This will be a better fit to EPICS and makes your driver useful to RTEMS folks, too.
On May 1, 2011, at 7:38 PM, Szalata, Zenon M. wrote:
> Till, Thank you for your input.
> I understand your suggestion.
> There is another related issue, which I am not sure about.
> In the existing driver code, the task is created with a call to vxWorks routine taskSpawn(...).  Here is a code fragment:
> int status;
> status=taskSpawn(...);
> taskwdInsert( status,NULL,NULL);
> This does not compile since taskwdInsert expects the first argument of type epicsThreadId.
> I am making a wild guess, that perhaps, before calling taskwdInsert routine, I need to call epicsThreadGetID, which should return epicsThreadId type identifier, which then I could pass to taskwdInsert.
> Seems that it should work, but having little experience with tasks, I would like an assurance that this the right way.
> Thanks Till,
> Zen
>> -----Original Message-----
>> From: Till Straumann [mailto:[email protected]]
>> Sent: Saturday, April 30, 2011 11:26 PM
>> To: Szalata, Zenon M.
>> Cc: Williams Jr., Ernest L.; EPICS Tech Talk
>> It seems that the epicsThreadId in the vxWorks implementation of
>> OSI is just the vxworks TID. Hence, passing a vxworks TID that
>> you obtain using straight vxworks calls on to EPICS and casting
>> to (epicsThreadId) should work but is of course extremely
>> ugly since you rely on non-public implementation details
>> (and you have no guarantee that these will not change in
>> future EPICS releases).
>> Your example would be much better using EPICS APIs only:
>> epicsThreadId tid;
>> /* EPICS_THREAD_NAME is 'const char *' */
>> if ( (tid = epicsThreadGetId( EPICS_THREAD_NAME )) ) {
>>   taskwdRemove( tid );
>>   /*** see comment ***/
>> Note that the EPICS API doesn't offer an equivalent for
>> 'taskDelete()' and this probably for good reasons: Just
>> asynchronously deleting a task is almost always a very bad
>> idea since you have no control over what the task is doing
>> when you pull the rug under its feet.
>> You need to implement a synchronization mechanism to let
>> the task know that it should terminate and then wait
>> for termination instead of using 'taskDelete()'.
>> HTH
>> -- Till
>> On 04/30/2011 11:08 PM, Szalata, Zenon M. wrote:
>>> I am working to upgrade an old device driver module so it can be used
>>> with EPICS R3.14.11 and vxWorks 6.6. It is currently used with EPICS
>>> R3.13.2 and some older version of vxWorks. The author is using the task
>>> watchdog routines in a way that I find confusing and am not able to make
>>> a decision on how to proceed.
>>> The task watchdog routines in EPICS R3.13.2 take int argument. An
>>> example is void taskwdRemove(int tid).
>>> In EPICS R3.14.11 this routine is now epicsShareFunc void
>>> taskwdRemove(epicsThreadId tid).
>>> The argument is now is a pointer to a structure. In itself, that is not
>>> surprising. The confusing part is that the author is using vxWorks
>>> routines, which use an int type handle and the EPICS routines which are
>>> called with the vxWorks handles. Here is a code fragment:
>>> int tid;
>>> if ( (tid = taskNameToId( NAME )) != ERROR )
>>> taskDelete( tid );
>>> Compiler does not like this because an int type is passed where a
>>> pointer to a structure is expected.
>>> Type casting the argument to the correct type would please the compiler,
>>> but I fail to see how this could possibly work correctly.
>>> Part of my problem is that I started to work with EPICS with R3.14.9, so
>>> R3.13.2 seems prehistoric
>>> Someone might ask a legitimate question, why bother with this old code?
>>> In fact I have a new device driver, which works with new applications.
>>> Unfortunately, the "old" IOC, which is using the driver in question is
>>> using a fairly extensive set of records and these would have to be
>>> modified substantially to make the IOC work with a new device driver
>>> code. So, I think that upgrading the device driver and preserving the
>>> .db files is more likely to result in the upgraded IOC working as it did
>>> before.
>>> Any ideas are most welcome,
>>> Zen
Eric Norum
[email protected]
EPICS task watch dog Szalata, Zenon M.
Re: EPICS task watch dog Till Straumann
RE: EPICS task watch dog Szalata, Zenon M.
Prev: RE: EPICS task watch dog Szalata, Zenon M.
Next: Re: EPICS task watch dog Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
