1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS task watch dog
To: "Szalata, Zenon M." <[email protected]>
Cc: Eric Norum <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 02 May 2011 09:27:55 -0500
On 05/01/2011 11:32 PM, Szalata, Zenon M. wrote:
Thank you Andrew, Eric and Till,
My thinking was to upgrade the existing IOCs and support modules
needed by those IOCS with minimum necessary modifications to avoid
altering functionality.  Part of the problem is that the IOCs use
extensive and complicated sets of EPICS records, custom record types
for which support is built into the device drivers (support modules)
and I am not very familiar with the inner workings of all that. So, I
was thinking to do the transition in two steps; first to just get the
software upgraded and moved from the solaris platforms where the
software is presently maintained, the second would be to take one
system at a time and re-implement
^^^ please note that just 'OSIfying' a driver is a *much* easier
task (which can often be done by just using a set of macros
or sed scripts) than re-implementing a driver. Can usually be
achieved in a few hours.
- T.
all device drivers to be OSI as
needed, perhaps using asynPortDriver... I realize that once the first
step is completed successfully, the second step may never be taken.
Zen
-----Original Message----- From: Andrew Johnson
[mailto:[email protected]] Sent: Sunday, May 01, 2011 8:33 PM To:
[email protected] Cc: Szalata, Zenon M.; Straumann, Till
Hi Zen,
On Sunday, May 01, 2011 21:38:53 Szalata, Zenon M. wrote:
Till, Thank you for your input. I understand your suggestion.
There is another related issue, which I am not sure about. In the
existing driver code, the task is created with a call to vxWorks
routine taskSpawn(...).  Here is a code fragment:
Actually if you follow Till's suggestion properly you would replace
*all* the calls to vxWorks-specific routines in the driver with
their EPICS equivalents. Instead of taskSpawn() you use
epicsThreadCreate(), etc.  This has the advantage that the
resulting code can be compiled for and will run on RTEMS, but it is
a bit more work since the EPICS versions are not all direct
replacements for their vxWorks counterparts.  Eric Norum produced a
Wiki page describing the conversions of the various routines, which
you can read at this link:
http://www.aps.anl.gov/epics/wiki/index.php/How_to_make_your_EPICS_driv
er_operating_system_independent
If you don't want to put that much effort into this, on vxWorks you
can just cast an epicsThreadId into an integer for use as a task-id
in vxWorks routines and vice-versa.  That is not possible on other
operating systems though.
HTH,
- Andrew (waiting for Obama's special news conference to start)
EPICS task watch dog Szalata, Zenon M.
Re: EPICS task watch dog Till Straumann
RE: EPICS task watch dog Szalata, Zenon M.
Re: EPICS task watch dog Andrew Johnson
Prev: RE: EPICS task watch dog Szalata, Zenon M.
Next: EPICS on RTEMS crashing on CA access, due to GNU readline?!? Angus Gratton
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: mca R7-0 Mark Rivers
