1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS on RTEMS crashing on CA access, due to GNU readline?!?
To: tech-talk <[email protected]>
Date: Wed, 04 May 2011 10:22:32 +0200
On 04.05.2011 05:26 Angus Gratton wrote:
On Tue, 2011-05-03 at 21:59 -0500, Mark Rivers wrote:
When I originally had this problem there was also a bug in EPICS base that was causing it to call the timer functions signal handlers incorrectly.  That code has since been removed from EPICS.  I don't think I have revisited the readline problem since then, so perhaps it is no longer an issue?
Do you know if this bug would have been fixed after 3.14.11, or would it
have been at some earlier time?
The EPICS SIGALRM handler was removed in R3.14.11. [1]
~Ralph
[1] http://www.aps.anl.gov/epics/base/R3-14/11-docs/RELEASE_NOTES.html
EPICS on RTEMS crashing on CA access, due to GNU readline?!? Angus Gratton
Re: EPICS on RTEMS crashing on CA access, due to GNU readline?!? Angus Gratton
RE: EPICS on RTEMS crashing on CA access, due to GNU readline?!? Mark Rivers
RE: EPICS on RTEMS crashing on CA access, due to GNU readline?!? Angus Gratton
Prev: RE: EPICS on RTEMS crashing on CA access, due to GNU readline?!? Angus Gratton
Next: RE: Does EPICS Base support multi-thread on vxWorks 6.3? lorna . zhang
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: EPICS on RTEMS crashing on CA access, due to GNU readline?!? Jeff Hill
